Old 04-23-2016, 11:55 AM   #1
Sajman
My Ride: Bmw 318i e46 2003
Cold Start problem
Hi hope someone can help me I just got a 318i e46 2003 when it's cold it starts up straight away then after about 4 seconds it cuts out. I have to keep cranking it about 10 seconds then it starts again then cuts out I have to repeat process about 5 times then it starts if I give it gas it cuts out then I start it again idles really rough car shakes. When car reaches normal temp idle settles down no misfires sounds perfect drives OK too. Has anyone else had this problem will post fault codes later.
Thank you
Sajman is offline   Reply With Quote
Old 04-23-2016, 12:03 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
http://forum.e46fanatics.com/showthread.php?p=16727145
http://forum.e46fanatics.com/showthread.php?t=929501
Old 04-24-2016, 06:53 AM   #3
markusmarkus
My Ride: 2001 330Ci
My opinion is link #2!
Old 07-09-2016, 01:15 PM   #4
Sajman
Do these impa analogue values look right for BMW e46n42 318i
ID:	636347   Click image for larger version
ID:	636348   Click image for larger version
cold start, misfire, rough idle
