Old 10-14-2016, 05:10 AM   #1
Aloofmind
My Ride: 2003 325i
Strange issue Help!
Hello, I am new to the forum and wondered if anyone has ever had this issue before. I have a 2003 BMW 325i that I bought 3 months ago. Everything is in working order as far as I know. I have an issue where when I have the car off and no key in the ignition. The interior lights, exterior lights. And dash lights will come on at random. I can also hear the fuel pump Come on at times. This is totally random, and everything works fine when the car is on. Its like I have put the key in the ignition and turned it to the on position. It does this every day/night . I have no idea what it is?
Aloofmind is offline   Reply With Quote
Old 10-14-2016, 06:06 AM   #2
e46_txi
My Ride: E46 330
Is your car equipped with an anti theft system? Did you read failure codes? Are you sure with the fuel pump? Check the EWS (immobilizer). You got a pre-heater installed?
e46_txi is offline   Reply With Quote
Old 10-14-2016, 06:12 AM   #3
Aloofmind
My Ride: 2003 325i
The car doesn't have a preheater. I am wired for a anti theft system but as far as I know it isn't installed. The sound is coming from. The back of the car so I'm assuming fuel pump priming. I'll have to check the EWS.
the only code I get is p0456 I haven't had the chance to track down the culprit of that code, I did replace the gas cap though
Old 10-14-2016, 06:26 AM   #4
e46_txi
My Ride: E46 330
What you describe (I also think the car acts like a iginition step 1 is on) should also switch the radio on (if you left it on), ever seen this? You say exterior lights switch on, do you have automatic light setting available on your LCM and do you use it? If not, exterior light switching on is a strange fact.
Old 10-14-2016, 06:33 AM   #5
N95
My Ride: 330i
Symptoms of a failing battery and low system voltage.
Test the battery voltage after running the engine, it should be at least 12.7 volts.
N95 is offline   Reply With Quote
Old 10-14-2016, 06:33 AM   #6
Aloofmind
My Ride: 2003 325i
I do have the auto feature for the lights but I rarely use them. I have the xenon headlights. But yes they come on for about 5-10 seconds then go off.
Old 10-14-2016, 06:40 AM   #7
Aloofmind
My Ride: 2003 325i
I just went to check the radio and I can turn it on without the key in at all
Old 10-14-2016, 06:41 AM   #8
jfoj
My Ride: 330CiC, M5, X5, E93
I would start with testing the battery as suggested, then I would consider replacing the ignition switch, these are known for intermittent problems.
Old 10-14-2016, 06:43 AM   #9
Aloofmind
My Ride: 2003 325i
Im going to have the battery tested soon, I'll post the results.
Old 10-14-2016, 06:44 AM   #10
e46_txi
My Ride: E46 330
It could be only the lightswitchmodule, next time leave your radio on and see if it switches on, too. If not, its propably "only" the lightmodule.
Its not about the fact, that you can turn it on without key, the question is: when you leave it on when taking the key out it will switch off, but does it switch on when the lights switch on automatically after you locked the car!
Old 10-14-2016, 06:48 AM   #11
venerated
My Ride: 325xi / Mazda3
I had this issue in my old Mazda after I did some work under the dash. Turned out that some wires were touching under the dash. Just a thought that something could be wired incorrectly.
Progress Thread / Twitter / Instagram
2003 325xi Jet Black/Brown Leather
2016 Mazda3 s Grand Touring Jet Black Mica/Black Leather
Originally Posted by mpvue View Post
a list of parts to replace on these is easy; just replace everything.
venerated is offline   Reply With Quote
Old 10-14-2016, 06:51 AM   #12
Aloofmind
My Ride: 2003 325i
I've been in the car when it happens many times, and I usually don't turn off the radio when I turn off the car. I've never seen the radio come back on during one of these episodes.
Old 10-14-2016, 08:13 AM   #13
e46_txi
My Ride: E46 330
The get a used light module (look for the correct specs: Xenon yes/no, foglights yes/no, light sensor yes/no) it is changeable within 5min.
dash guages, fuel pump, lights
