No start/no crank - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 11-08-2016, 02:16 AM   #21
Swiff
My Ride: 2002 330xi
Check to see if you are getting power to the alternator big power wire terminal and the positive battery terminal jumper under the hood.
In your trunk there are 2 separate big wires that come off of your battery. One of the big wire goes up under a cover by the wheel well for the interior electronics and has a 200 amp fuse there. The other one goes to the alternator and starter. It lays on the floor of the trunk and goes by your rear seat.
Swiff is offline   Reply With Quote
Old 11-09-2016, 07:02 PM   #22
Qwest
My Ride: 2004 330xi
No start/no crank
Just tested old starter and it spins but doesn't pop out leading me to believe it was a solenoid issue. However the current starter and the old one wouldn't spin at all when Connected in the engine. Tested voltage to the starter and it is receiving power from the battery.
Qwest is offline   Reply With Quote
Old 11-10-2016, 01:49 AM   #23
Swiff
My Ride: 2002 330xi
Most likely it is the EWS module or the antenna ring. If you are not getting power to the activation wire of the starter it comes from that module. You can try re-checking the pin connections coming out of the EWS to see if you are getting power while the key is in the cranking position. Other than that it may have to go to the shop to get module and or programming.
Old 11-10-2016, 01:52 AM   #24
Qwest
My Ride: 2004 330xi
I thought if it was the ews the engine would still still crank but the injectors wouldn't flow?
Old 11-11-2016, 06:41 PM   #25
Swiff
My Ride: 2002 330xi
The EWS and the DME provide the starter solenoid with power and ground.
Name:	E46 starter wiring diagram.jpg
Old 11-11-2016, 07:46 PM   #26
Swiff
My Ride: 2002 330xi
The black and yellow wire goes to the top of the starter where you see the strap has a lead going to that pin.
The black wire goes on the bottom.
Lower photo courtesy of pelican parts
Name:	E46 starter wiring.jpg
ID:	644985   Click image for larger version
Name:	E46 starter wiring2.jpg
Old 11-11-2016, 07:48 PM   #27
Qwest
My Ride: 2004 330xi
That is how I have it hooked up. I used pelican parts for pulling my intake off and a diy on here for doing the starter before I decided to just take the intake off.
Old 11-12-2016, 05:11 PM   #28
Swiff
My Ride: 2002 330xi
Found this video also. Did you try another key (if you have one).
Old 11-12-2016, 05:12 PM   #29
Qwest
My Ride: 2004 330xi
I only have the diamond key. I don't have a duplicate or valet key
Old 11-13-2016, 03:43 PM   #30
Swiff
My Ride: 2002 330xi
When you put the key in the ignition and the door is open, do you hear a beeping noise? Did you also check the fuses under the hood where the DME is located?
I also found a "No start" thread in the general forum area. No start by lszlszx. Most of the stuff I think we covered but this guy goes into more detail. There were post made by other people while he was making the thread and also he added some fixes during the thread.
Old 11-13-2016, 03:47 PM   #31
Qwest
My Ride: 2004 330xi
It does beep with the door open. I ordered the Bmw scanner everyone recommends, which should read any ews codes. I did check under the hood fuses
no crank, no start
