E46 Xi Forum
Old 11-17-2014, 10:45 PM   #1
FrotheAntihero
My Ride: 03 325xi 93 325is
2003 325xi broke down today HELP!
I love BMW but dam. this is my 2nd one its a 2003 325xi auto ive only had it 2 months tomorrow it has only 123k mi on it and has ran like a dream. All but the once in awhile low idol. Anyway when i got off work I let my car warm up for a good 10 min as I did this morning as it is brutally cold here in Indiana today. I got about halfway home and dropped my buddy off at his house as i pulled off all the sudden I pressed the gas and the car didnt move.Then as it reved higher I heard a GNARLY sound metal on metal possibley. I took my foot off the gas and pushed my car to the side of the road I tried every gear nothing no clunk into gear nothing. As my tow truck buddy got to me we realized the car rolls freely in park. The trans has never even shifted hard. If i can figure out the problem I can fix it but I have searched for hours online and the only thing close to the same problem I found was on a 08 X5 and it was the transfer case . Please help. I miss my car already.
FrotheAntihero is offline   Reply With Quote
Old 11-18-2014, 12:07 AM   #2
FrotheAntihero
Anyone had anything like this ever happen?
Old 11-18-2014, 01:03 AM   #3
Kubica
My Ride: 2003 325xi
Hopefully it's just a blown axle.
Old 11-18-2014, 07:51 AM   #4
jeepo23
My Ride: 2008 X3, 6 Speed
1) It's not good for your car to warm up.. Not sure how cold it is where you are but it can't be any colder than down in East Coast Canada.
2) Sounds like a blown transfer case or maybe even transmission
** Removed **
jeepo23 is offline   Reply With Quote
Old 11-18-2014, 08:19 AM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
Do not recall how the front axles attached to the transfer case, but if they are snap in axle, one may have popped out.
If one of the axles pops out, the car will not move and the car will not hold in park.
Otherwise the transfer case or differential may be an issue.
Old 11-23-2014, 02:47 PM   #6
ixtoxi
My Ride: 02 330xi, 88 325iX
My bet is a broken CV joint in one of the axles.
ixtoxi is offline   Reply With Quote
Old 11-23-2014, 03:07 PM   #7
gabriox
My Ride: 2002 bmw 325xi
bmw says that you should drive your car in low speed to warm it up. not by revving it in park.
gabriox is offline   Reply With Quote
Old 11-26-2014, 09:45 PM   #8
MLB1949
My Ride: 2004 BMW 325XI Sport
Sorry to hear about your xi problems. Let me share my experiences. Oct. 13th, 2014 I bought a 2004 325xi Sport Wagon with 110,480 miles. The previous owner left receipts for the four years of ownership, totaling $8,000 parts and labor. It thought the car had been well maintained and I probably wouldn't have to spend much to own it. So far I've replaced a defective steering angle sensor, paid the dealer to program the new steering angle sensor, replaced two broken rear coil springs, had the rear view mirror re-manufactured, replaced a leaking right front axle shaft seal, and replaced both motor mounts. Today I realize that my power steering pump is worn out and I have a recurring P0171 and P0174 codes being generated. Wow, I'm thinking this is my last BMW. The good part is the paint is brilliant, the leather interior is impeccable and the handling is superb. Oh well, maybe it isn't so bad after all. It's such a pleasure to drive when the gremlins aren't causing problems!
MLB1949 is offline   Reply With Quote
Old 11-26-2014, 11:58 PM   #9
Wolfpacker
My Ride: 2003 325xiT
So, OP, what was it??
Wolfpacker is offline   Reply With Quote
Old 02-28-2017, 11:03 AM   #10
Koolaidguy
My Ride: 2003 BMW 325xi
I know this thread is dead but in case anybody else is having similar issues, I had the EXACT same issue as OP and it turned out my front left cv axle had broken. I sincerely hope this helps anybody else who is experiencing these problems.
Koolaidguy is offline   Reply With Quote
Old 02-28-2017, 08:41 PM   #11
jmo69
My Ride: 03 325xi 98 328is
They don't even have to break, just pop out of the dif a little.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is online now   Reply With Quote
325xi, transfer case, transmission
