Old 01-28-2016, 08:12 PM   #1
Kammmiiil
My Ride: 1999 E46 328i
Diy: Seafoam in your e46
How to run SEAFOAM Motor Treatment in your E46:
Kammmiiil is offline   Reply With Quote
Old 01-28-2016, 08:27 PM   #2
SK330ci
My Ride: 02 330ci w/ 3 Pedals
You should ask any German car dealer tech why they don't use that stuff, then ask them what they actually use.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 01-28-2016, 10:24 PM   #3
swordsman11868
My Ride: 2003 325i
Why?
Edit: directed to the OP
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 01-30-2016, 03:56 PM   #4
BKMrSteel
My Ride: 99 328i
This makes me want to cry a little...
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 01-30-2016, 05:07 PM   #5
boblaz
My Ride: 03 BMW 325XiT
Why do the replies give the effect of doom but don't bother saying why. Many many people have used Sea Foam for decades without issues. So why the posts of doom? If you have something to say how about just saying it?
boblaz is offline   Reply With Quote
Old 02-24-2017, 11:59 PM   #6
JohnnyFaire
My Ride: 2003 330i automatic
Try being more cryptic. Your just waaaay too helpful.
Sent from my XT1563 using E46Fanatics mobile app
JohnnyFaire is offline   Reply With Quote
Old 02-25-2017, 12:00 AM   #7
JohnnyFaire
Dude in the video uses it, I've used it. No problems so far. Will update if problems occur.
Old 03-05-2017, 08:15 PM   #8
EXNoodle
My Ride: 330CI
Send a message via AIM to EXNoodle
179,000 miles on my 330 zhp and I have used the stuff at least a dozen times. I notice a small difference when I put it in the gas tank, notice the largest difference when I do the 1/2 in the engine, 1/2 in the gas tank and a 1/2 from an other bottle in the exhaust cold start fan, following all the procedures outlined here on the forum.
I am a common sense engineer, a lot of positive feedback here and in my personal use. I have also borescoped my cylinder heads before and after, it does clean them up nicely.
German car dealer techs must follow the OEM's instructions. I work for a OEM, we are not always as smart as we think we are. Arrogance is the killer of good ideas, that is what I see on the OEM side of the world, especially w/ the larger OEM's.
Gray 2004 330CI ZHP
EXNoodle is offline   Reply With Quote
Old 03-07-2017, 12:23 PM   #9
JohnnyFaire
What/where is the "exhaust cold start fan"
Old 03-08-2017, 01:23 AM   #10
dck8267
My Ride: 2003 325ci M56
He means secondary air pump I think
Sent from my SAMSUNG-SM-G930A using E46Fanatics mobile app
dck8267 is offline   Reply With Quote
Old 03-08-2017, 01:26 AM   #11
dck8267
Also I have used it only in intake, but I use brake booster line and in my car you have to keep the rpms up above 2k for it to not try and stall and let it run for a couple minutes after before turning it off or it will "diesel" and attempt to keep running with key off, let sit for 30 min then smoke out the neighbors lol, but I'd never use it in the oil, use correct oil and change frequently and u wouldn't need it anyways.
Old 03-11-2017, 08:15 AM   #12
EXNoodle
My Ride: 330CI
Your correct dck8267. Thank you for the clarification on my behalf.
Gray 2004 330CI ZHP
Old 03-11-2017, 08:08 PM   #13
Delineation
My Ride: JapanRot 05 325i
Waiting for Jfoj to swing in and talk about running it for 1k miles in the oil. I've done that and had no issues. I recently did a compression test on my 325 with 181k+ miles on it and the lowest was averaging 161-180 on the cylinders; on a cold engine. Seems to be fine.
Jfoj could elaborate but I believe it's because our sump is rather large & that a full can down the hatch is fine for about 1k miles before an oil change. I add it with the engine running and very small amounts at a time.
They said I could become anything, so I became a BMW owner.
Delineation is offline   Reply With Quote
Old 03-13-2017, 12:45 AM   #14
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Did this two years ago. No issues and would do it again
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
diy, e46, fuel injector, how to, seafoam
