Old 09-06-2013, 01:28 AM   #21
HakenTT
My Ride: 323i with S54
Originally Posted by FryGuy View Post
That's what I thought. They also want $2500 for parts and $2300 for labor for the swap. Not sure if that's reasonable
Engine swaps are expensive to do in the shop, also shop just orders stuff from the dealer, they don't waste time with ebay and used parts. Unless you will do the job yourself I don't see this being practical thing to do. Sell your junk and buy better is what people tend to do.
HakenTT is offline   Reply With Quote
Old 09-10-2013, 01:50 PM   #22
BMWinLinE6
My Ride: E46 sedan
Any progress on your swap? I have done the same to my car. Issues that I have:
1. 330 MAF does not work. I have tried with different 330 MAF's, none worked. But when I swap back with 325 MAF, it worked immediately. I suspect I need to reflash my ECU to adapt 330 MAF? Feels strange.
2. I got "Intake Cam Position Sensor" error with the donor engine. I replaced both intake and exhaust sides Cam Position Sensors with brand new ones, but no luck. Suspecting some wiring issue.
BMWinLinE6 is offline   Reply With Quote
Old 09-11-2013, 04:48 AM   #23
the_carp
My Ride: 2001 325CI Coupe
That is my engine all up and running
The guys said it was a pretty straight forward swap, or what we call plug and play
I never had my ECU reflashed either, I just swapped these parts over
ECU, EWS And the ingintion barrel, and my boot lock, So Im using the 330 keys.
My only issue is that my remote locking not working, but im looking into that.
The car Idles and runs great, Much more power and acceleratrion is great
Anything you need give me a shout
the_carp is offline   Reply With Quote
Old 09-11-2013, 05:03 AM   #24
the_carp
I belive the 330 Maf is essential in the swap, and must be changed
I fitted a k&n and used the 330 Maf and its fine
I cant see the wiring being a issue mate, un hook the battery for half hour and fingers crossed it will clear them
Old 09-11-2013, 07:42 AM   #25
Guest021715
Account closed.
Sounds like you did too much work, and still didn't get the full functionality you needed.
Old 09-11-2013, 08:07 AM   #26
BMWinLinE6
My Ride: E46 sedan
You used 325 stock tune and 330 MAF worked fine? I haven't reflashed my ECU, so it is still the stock 325 tune, it works fine with 325 MAF, but not 330 MAF.
I thought maybe I need to get it reflashed to 330 tune first, but that probably shouldn't be the issue?
Old 09-30-2013, 09:07 PM   #27
BMWinLinE6
My Ride: E46 sedan
I figured out the MAF issue. It was just a bad MAF. Replaced with a good 330 MAF and worked great without new tune.
And I finally reflashed my DME with V41 330 tune. Haven't fully tested but expecting some power gain.
Old 09-30-2013, 09:31 PM   #28
FryGuy
My Ride: 2001 325Cic w/ B30
Confirmation - 325 to 330 Engine swap
For a day I was driving around with my B30 swap with a 330 MAF and air box, pre ecu tune. After I got the update the difference was night and day. More power, better throttle response, and better MPG. Make sure to reset the lambda adaptations after the update.
FryGuy is offline   Reply With Quote
Old 09-30-2013, 09:45 PM   #29
BMWinLinE6
My Ride: E46 sedan
Thanks! I already cleared all adaptations, and key on for 30 seconds to re-learn all adaptations.
What ZUSB did you use to reflash with 330 tune? I used 7571613. I saw some other numbers (all refer to e46 330) for the same MS43 DME. Not sure if there's any difference. But I went ahead using 7571613 and reflash was successful.
Old 09-30-2013, 10:23 PM   #30
FryGuy
I can't recall which one specifically, but what I did was got the vin of a 2001 330Ci convertible manual from auto trader and put that in for the proper update.
Old 02-05-2014, 05:03 PM   #31
djdirec
My Ride: has roof rails
Originally Posted by TerraPhantm View Post
Just swap everything over and get your DME reprogrammed (I can do that for you if you'd like). Shouldn't be any more difficult than swapping another 325 engine.
For year to year differences..
If it comes out of an xi you'll need to swap oil pans, and there are some minor differences based on year. 2003+ engines use different coils; swap the valve covers and use your stock coils. 2003+ engines use 4-rib pulleys with the AC belt -- just use a 4 rib belt; works fine. 2003.5+ mon-XI motors are MS45 and have the IAT sensor integrated in the MAF; get a 330 3-pin MAF and swap the IAT sensor from your original engine
TerraPhantm, I tried to send you a PM but your storage is full
Touring the bimmer
djdirec is offline   Reply With Quote
Old 02-05-2014, 05:07 PM   #32
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
I'm still waiting for pics of said "330 saloon vert"
Cavi Mike is offline   Reply With Quote
Old 11-22-2015, 01:03 PM   #33
rawbspear
My Ride: 04' E46 XIT 5 speed
i think i may have killed my 325 motor in my 04 XIT. So i am asking this as a worst case scenario : Does a 330 coupe motor fit in the wagon? is there a better motor i could/ should/ can put in my wagon? i have lots already invested in my car and i just chocked on the prices for a new rig; makes more sense to pimp it out than get a new project.
rawbspear is offline   Reply With Quote
Old 11-22-2015, 04:24 PM   #34
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
No it will not fit. You have an Xi and you need an Xi motor. Otherwise you will have to change out external pieces onto the new motor.
A 330i motor will fit, but you have to change out the oil pan, the flywheel if different, and all the little things that need changing:
Intake gasket
CVV
Rear seal
Vacuum lines
etc...
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 11-23-2015, 12:38 PM   #35
rawbspear
so if it was a 330xi that would be easy? or shall i say easier?
325, 330, engine, replace, swap
