Old 08-31-2013, 08:35 AM   #1
the_carp
My Ride: 2001 325CI Coupe
2001 E46 325CI Now with 330 Engine - How to re-flash ECU
Hi All,
I have just fitted my 325CI with a 330 Engine, However when you put the 330 ECU in the car wont start, but when you put the 325 (original ECU) the car starts & drives although it does seem very rough & don't really want to drive it.
Does anyone have any ideas? I dont want to start to download software etc... as im awfull with computers
I still have both ECU's - I have phoned lots of remap specialists, and know one seem to be able help, I have phoned BMW who really dont seem to care
The ECUs are both the same pre 2003 M43 i think
Any help would be appreciated
Thanks in advance
Ian
the_carp is offline   Reply With Quote
Old 08-31-2013, 08:49 AM   #2
M3J0N
My Ride: See Sig
Send a message via AIM to M3J0N
EWS alignment is the first thing I would consider
-M3J0N
98 M3/4/5Arctic/Dove (Sold)
99 M3/2/5 Titanium/Black (Sold)
04 M3/2/6 Carbon Black/Black (Sold)
95 M3/2/5 Carbon Black/Black (Sold)
95 M3/2/5Avus/Dove Grey 3.2L Swap (Current)
90 M3/2/5 Diamond Black/Black 3.0L Swap (Current)
96 M3/2/5Estoril Blue/Black (Current)
01 325iT Wagon Auto Titanium Silver/Red Sport (Current)
M3Forum Is a Joke (lifetime ban):
http://m3forum.net/m3forum/showthread.php?t=500115
M3J0N is offline   Reply With Quote
Old 08-31-2013, 08:49 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Likely you have issues with the EWS and keys?
EWS have to be married and key has to he configured to work with EWS.
Do you have the car that the engine came out of? Likely you would need the EWS, lock cylinders, keys and possibly even the cluster to make it work easily, otherwise you are going to need to deal with software programming and/or reflashing.
Assuming the DME's are the same, you may be able to flash the DME with the programming for the VIN on the original car?
But I have no idea how the EWS will play into all of this if you flash with the VIN from the original car, there are other modules that have VIN coded into it them so there may be some other unusual behaviors?
There are folks on the the forum here that have performed complete engine swaps and can likely tell you what is required.
Cyberkaa is one that comes to mind.
TerraPhantm may be another good source.
Old 08-31-2013, 09:35 AM   #4
TerraPhantm
My Ride: M3 & ZHP
Buying the dme was a waste. You won't be able to align it with your EWS. You can flash your 325 DME with 330 software though
Old 08-31-2013, 10:06 AM   #5
the_carp
hi Terra,
Any idea How can i do this? i havn't found a indy yet that will do it for me
Will this do it?
http://bmtechnic.co.uk/
Old 08-31-2013, 11:27 AM   #6
BMWespresso
My Ride: 2005 325CI
check with this folks; they link keys ECU and EWS they did this for a Mini Cooper that we changed the ECU.
http://www.rmsonlinestore.com/main.sc
BMWespresso is offline   Reply With Quote
325ci, 330, dme, ecu, reflash
