FS: 2003 Dinan S3-R M3 -- Highly Modded - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars - Private
Old 10-27-2013, 02:27 PM   #1
mdheller
My Ride: M3
Smile FS: 2003 Dinan S3-R M3 -- Highly Modded
I purchased this car several years ago from the local BMW dealership. This car was originally used as their "show car" for Dinan & other performance products--it has just about everything you can do to an E46 M3 and keep it street legal. The backseat of this car has been removed and it has a rear cage. The interior was re-carpeted in the back to keep the car looking nice inside.
The car runs perfectly. I've sorted the car very well over the past few years and would reason to say that, at this point, nearly every common and uncommon fix has been taken care of including vanos, headliners, water pump, coils, plugs, fuel pump, etc.
Most of the rubber in the backend of the car was replaced by Poly for a more rigid and stiff set up.
The battery was replaced with an Optima Redtop.
The car comes with a master battery kill-switch, brake light kill switch and tail lights/license plate light kill switch, these bespoke options are wired up to a carbon fiber switch panel in the cockpit for good measure. The car comes pre-wired for a ValentineOne.
The car also comes from the factory with no sunroof and an M-Cloth interior.
I have a mountain of invoices from high-end and very well respected motorsports shops for nearly all of the work that was done to the car since I purchased it.
I purchased this car with 44k on it in 2007 and I've only driven the car 24k in the entire time I've owned it. The car has seen a few track weekends but it is by no means a beat-up track car. I have the compression/ leak down test results to show that this car runs like new and I am happy to provide any serious buyers along with the names and phone numbers of the professionals that have worked to properly maintain this car over the past several years. This car is a total gem, period.
I always said I would keep this car forever, but I guess we all get old at some point and decide to sell our toys.
Dinan Features:
Intercooled Supercharger System
Enables 462 HP @ 328 ft/Torque includes:
Vortech Gear -Driven Supercharger Compressor (5.5psi)
Large Air to Air Intercooler with High Flow Cast Aluminum Tanks
Automatic Intercooler Auxiliary Fan
CNC Aluminum Steel Mounting Brackets
High Flow Cold Air Intake
High Capacity Fuel Pressure Regulator and Fuel Injectors
Automatic Belt Tensioner
High Capacity Aluminum Radiator (35% increase)
High Capacity Oil Cooler (provides 100% increase)
Comprehensive Engine Management System Calibration
High Flow Throttle Bodies
Larger Internal Diameter Increases Power (provides more immediate throttle response)
Free Flow Exhaust
Reduces Back Pressure for Improved Flow
Increases Horsepower and Torque
304 Stainless Steel:Reduces Weight & Resists Corrosion
Stage 2 Suspension
Street/Race Functional
Racing type Shock & strut
12 way adjustable
Camber plates
Camber Bars
Front Camber -5 degrees
Rear Camber -2.5 degrees
Strut Tower Brace
Shock Tower Brace
Brembo Grand Terismo Brake Kit
380mm front rotors, slotted with aluminum hats
345 rear rotors, slotted with Aluminum Hates
4 Piston Alluminum Calipers Front/Back
Goodridge Dot/TUV Approved Stainless Steel Brake Lines
Mounting Brackets Assembly Hardware Dinan-Spec
Pagid Ceramic Backed pads front/rear
3.91 Limited Slip Differential
Increase in Torque
Improved Aceleration
Minor Engine Speed Increase
No Reduction in Top End Potentiol
Allows car to reach >60 Mph in Second Gear
Short Shift Kit
Reduces Throw by 17%
Lowers Knob By 1/2"
AC Schnitzer Features:
Roof Spoiler
Aluminum Foot rest
Aluminum Hand Brake
Aluminum Pedal Set
CF arm Rest Kit
CF Dash kit
CF steering wheel insert
Vorsteiner Features:
M3 Vented Race Hood
M3 CSL Deck Lid
VRS Engine Cover
CSL Splitters
CSL Rear Diffuser
Um-Nitza Halo Kit
Safety Gear:
Recaro Pole Position Seats
OMP 6 Point Harnesses
Custom Rear Roll Cage
Fire System
Please call with any questions.
Michael
mdheller at gmail.com
ID:	532423   Click image for larger version
Name:	e 46 3.jpeg
ID:	532424   Click image for larger version
Name:	e 46 5.jpeg
ID:	532425   Click image for larger version
ID:	532427   Click image for larger version
mdheller is offline   Reply With Quote
Old 10-28-2013, 02:12 AM   #2
Asher454
My Ride: '04 TiAg 325xi
GLWS pure sex
234,XXX......... Factory M54
Asher454 is offline   Reply With Quote
Old 10-28-2013, 06:36 AM   #3
AudiEtr
My Ride: 330i
I just shat myself. Too much awesomeness.
AudiEtr is offline   Reply With Quote
Old 10-28-2013, 10:00 AM   #4
mdheller
My Ride: M3
I forgot to mention a few things, I am sure I am forgetting a few others too.
The tint is a ceramic tint. This means that you can more reliably use a glass mounted antenna on this car. Metallic tint interferes with the signal.
I have a euro tray cup holder delete. Trust me, this is much better.
I've removed the armrest-- anyone with any serious driving experience in an E46 knows how annoying it is when the armrest starts flopping around at speed. A arm rest delete is sold for $59-70 bux and makes everything purdy inside again.
thats all I can think of for now.
Old 10-29-2013, 03:46 PM   #5
mdheller
My Ride: M3
bump
Old 10-29-2013, 11:54 PM   #6
EgoKLLR
My Ride: E46 M3
Nice car, I think you forgot to mention the specs on your CCW C14's and tires. GL sale!
EgoKLLR is offline   Reply With Quote
Old 10-30-2013, 06:16 AM   #7
mdheller
My Ride: M3
yep
Nitto NT05 Tires, wheels are a single block aluminum billet wheel, it was actually hard to find a proper set of wheels to clear my huge calipers. I bought these CCW wheels at VIR from a guy who was getting ready to sell his E46 track car.
http://www.hutterperformance.com/Pro...CCW-Wheel.aspx
The tread on the back tires is worn by street standards, but according to my standards I know there is plenty of fun left on these and they have plenty of grip IMHO-- Just don't expect to put all 462 horses down when they are cold. When it comes to a R-compound tire that does not need to be heat cycled (Nitto NTO1/NT05 and plenty others) I have found that the NT05 is surprisingly good for street/track use. The way my car is set up one can expect to have fairly consistent grip on a new set of NT05's until about 100-110 in the rain (obviously this is a multi-factor equation).
Please let me know about any other questions. Thanks
Old 10-30-2013, 11:59 AM   #8
mdheller
My Ride: M3
Smile more pics
Here are a few more. If anyone wants to see anything up close I am happy to take more pictures.
Name:	e 46 3.jpeg
ID:	532782   Click image for larger version
Name:	e 46 7.jpeg
ID:	532783   Click image for larger version
Old 11-01-2013, 04:27 PM   #9
mdheller
My Ride: M3
Engine Bay pics
In case anyone was interested in seeing them.
ID:	533027   Click image for larger version
ID:	533028   Click image for larger version
ID:	533029   Click image for larger version
Old 11-05-2013, 05:26 PM   #10
mdheller
My Ride: M3
bump
Old 12-09-2013, 07:56 PM   #11
mdheller
My Ride: M3
this car was recently wrecked due to some 18yo dufis not looking before he turned into on coming traffic. I will be parting out the wreck soon. Stay tuned for details.
Old 12-09-2013, 08:09 PM   #12
Jimmy_46
My Ride: bmw e46 m3
Re: FS: 2003 Dinan S3-R M3 -- Highly Modded
Your ****ing kidding!! What a beautiful machine gone to waste. I'll be interested in parts for sure
Jimmy_46 is offline   Reply With Quote
Old 12-09-2013, 09:44 PM   #13
CK325
My Ride: 323Ci, 325xi
Damn was it that bad?
Surprised I haven't seen this beaut around Philly.
CK325 is offline   Reply With Quote
Old 12-10-2013, 09:34 AM   #14
mdheller
My Ride: M3
Here are some pics below. From a parting out perspective, I think it was a pretty clean hit. From a usability perspective, this frame and car are toast. I need to wait until I have a more definitive assessment back from the Insurance company but I figure I should have most of it taken care of within a week or so.
Nick, aka, 05M3Driver, I am not selling you parts so that you can resell them on M3 forum. I can part the car out myself.
ID:	538052   Click image for larger version
ID:	538053   Click image for larger version
ID:	538054   Click image for larger version
Old 12-10-2013, 09:46 AM   #15
mdheller
My Ride: M3
No deals LOL
sorry NICK
Name:	no deals.png
Old 12-10-2013, 01:45 PM   #16
CK325
Looks like hood, bumper, fender, maybe wheel and rad support.
Was the strut tower moved at all?
Let me know if you're willing to sell as is.
Old 12-10-2013, 01:54 PM   #17
ik47
My Ride: bmw m3 e46
Ye same here looks like easy fix !
ik47 is offline   Reply With Quote
Old 12-10-2013, 02:13 PM   #18
mdheller
My Ride: M3
I'm not sure it makes much sense to sell it as is; but, I will entertain offers if you send a PM. I wont be able to give any answers on parts until I have a final number from my insurance company.
Old 12-10-2013, 02:15 PM   #19
mdheller
My Ride: M3
From what I saw, the entire strut tower was crumpled but it did not look like there was any damage to the wheel. I'm surprised the wheel didn't go rolling away because there wasn't much left to hold it on.
Old 12-10-2013, 02:17 PM   #20
ik47
My Ride: bmw m3 e46
Dont matter . Just cut it out weld a new one . And thats it . Easy breezy. Did ton of work like that
csl, dinan, e46, m3, supercharged
