Old 11-05-2013, 07:17 PM   #1
add70816
My Ride: 2001 330Ci
replaced the fuel filter and pump and now the car is running a rough idle! HELP!
Hello, I have a 2001 BMW 330CI and i've replaced the fuel filter and fuel pump, now the car has a huge power lost, really rough idle and wont start unless i slam on the gas pedal in the morning. i have a cable tie holding the vacuum tube connecting to the fuel pump, i was told that may be the issue. the original fuel pump went out and the car wouldnt start until i put the new one on! the car ran fine for weeks but now im having that issue i stated up above! is there anyone who can help and tell me what i could possibly do to fix it!
add70816 is offline   Reply With Quote
Old 11-05-2013, 07:34 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Doubt is is the fuel pump, but you could check the fuel pressure and volume to confirm. Was the fuel sender gasket properly installed?
Would be concerned about the fuel filter and/or the vacuum line that connects to the fuel filter.
I assume you have a CEL/SES/MIL light on? If so, you need to have the codes read and check the Freeze Frame data.
If you do not have a scan tool or a tool that support Freeze Frame data, read this - http://forum.e46fanatics.com/showthread.php?t=967204
For other ideas, read the 1st link below in my signature.
Old 11-05-2013, 07:42 PM   #3
bmwbob89
My Ride: M-5 325 X3 528 740
What brand of parts did you use?
bmwbob89 is offline   Reply With Quote
Old 11-05-2013, 07:47 PM   #4
jfoj
After looking at this again, explain the above in more detail.
Did you purchase a complete fuel pump/sender unit or did you purchase only a pump from a local parts store and have to fit it into your original fuel level sender?
Old 11-05-2013, 08:18 PM   #5
add70816
My Ride: 2001 330Ci
i have a mann filter and the pump is bosch. also i just replaced the cable tie with a hose clamp. it ran normal for about 15 minutes then started the rough idle again. also i'm getting the lean fuel code.
Old 11-05-2013, 08:21 PM   #6
jfoj
Probably coincidental??
Was the Bosch pump a pump/sender complete unit?
What codes do you have? P0171/P0174?
Probably a vacuum leak, but you could verify fuel pressure and volume with a fuel pressure tester. Most auto parts stores have them for loan.
Old 11-06-2013, 06:55 PM   #7
add70816
My Ride: 2001 330Ci
Yes Sir, it is the pump and sender and those are the codes i'm getting, also i want to add that when i have my foot on the brake and press the gas i cant rev the engine like i could normally. has my fuel pump gone bad? because i changed the filter two weeks after the pump so could my old filter have made my new pump bad??
Old 11-06-2013, 07:09 PM   #8
jfoj
Doubt the pump is bad again, sometimes people connect the filter up wrong, most of the time they get no fuel, but I guess anything is possible with the wrong connections.
You should be able to rent/borrow a fuel pressure tester from most AutoZone/Advance stores. You need to check both pressure and pump volume.
Plenty of things make the engine run lean, however, vacuum leaks are usually minimized off idle and do not cause a lack of power.
Old 11-07-2013, 07:32 PM   #9
add70816
My Ride: 2001 330Ci
ok, so i just had the car scanned and i got these two codes p0505 and p0102! any ideas guys?
Old 11-07-2013, 08:17 PM   #10
lszlszx
My Ride: 1.8T, XC70
Disconnect the MAF briefly to see if the idle changes. Other than that, recheck your work make sure everything has been connected properly and look for vacuum leaks.
If it runs good at higher rpm, fuel delivery is good.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
fuel filter, fuel pump, low psi, rough idle
