Old 12-02-2013, 01:27 PM   #21
G3n15z
My Ride: '00 BMW 318i
Send a message via MSN to G3n15z
Just get a scanner and stop crying
G3n15z is offline   Reply With Quote
Old 12-02-2013, 02:11 PM   #22
Guest021715
Account closed.
Lol. I'll buy it from you and make it my DD winter beater within the week.
Old 12-02-2013, 04:10 PM   #23
328cic
My Ride: 2000 328ci
Wish it was that easy.
Help.me.out guys i ordered a scanner but i dont.onow.when itll.be here… till.now.any suggestions on.whats wrong?
328cic is offline   Reply With Quote
Old 12-02-2013, 04:13 PM   #24
Guest021715
Account closed.
Re: BMW 328ci WONT START!!!!!!!!!!!! HELP ME
Call a mechanic. You're in way over your head.
Old 12-02-2013, 04:30 PM   #25
328cic
My Ride: 2000 328ci
please just give me suggestions.on what could be wrong so i can atleast see if my car would start up with something minor?
Old 12-02-2013, 06:03 PM   #26
Guest021715
Account closed.
Unplug your MAF and try starting, like already said.
If you don't know what something means, search here or use Google.
Old 12-02-2013, 06:04 PM   #27
lszlszx
My Ride: 1.8T, XC70
Go back to the basics, check for spark and fuel.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 12-02-2013, 06:35 PM   #28
ca5ua1ty
My Ride: 2001 330CI
Step 1: Proof read messages before sending.
Step 2: Call AAA. They will tow your car to a shop of your choosing. I always have a list of indys should something happen to my car that I cannot fix
Step 3: Get a Credit Card Ready
Step 4: Debt. Welcome to owning an older BMW.
"In a world full of ordinary, you need to stand out with something a little extraordinary."
ca5ua1ty is offline   Reply With Quote
Old 12-02-2013, 06:48 PM   #29
Cowspoo
My Ride: 328Ci
Originally Posted by lszlszx View Post
Go back to the basics, take your car to a mechanic.
Fixed
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 12-02-2013, 07:07 PM   #30
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If you sprayed around the intake boot and it popped, then that tells me you have a tear in your intake boot...that it popped the intake boot off sort of tells me you didn't put it back on right either.
If the intake boot has a sizable tear in it...very common...that's where I'd start...replace the intake boot and make sure it's on right. While there, you might as well clean the TB too. If the boot isn't on, you'd probably have a huge problem starting the car. A small tear or minor vac leak the car can manage, but not a massive hole. The car knows it's lean, puts in a lot more fuel, but it doesn't really need that much fuel. Have you tried starting it with your throttle down to the floor--(maybe halfway down?)...which is how you start a flooded engine.
If that works, you need to come to one of my shows as payment!
hth...and a bump...and honestly, if that's not it...take it to a mechanic. You could be a couple hundred dollars away from having your car running. Could be a sensor...could be a fuse you didn't find.
Did you check your Kalim Fuse?
See me in June!
dmax on Facebook
Mangofy your E46!
Old 12-02-2013, 07:24 PM   #31
GhostFlame
My Ride: E46 Sedan
Have you tried turning the car on and off?
GhostFlame is offline   Reply With Quote
Old 12-02-2013, 08:53 PM   #32
328cic
My Ride: 2000 328ci
Hey well.i put the tube on tight and.started cranking it the rpm doesnt go past 300 while cranking so its not even bugging to start and the throttle pressed all the way doesnt do anything. Theres fuel pressure in the fuel line as i checked but the throttle doesnt seam to get my engine churning.
Old 12-02-2013, 11:56 PM   #33
328cic
My Ride: 2000 328ci
So i got a code reader and i almost cried seeing all the codes. Ive only had this car for a while and 4th owner so its been neglected
Help me out guys heres the codes
Old 12-02-2013, 11:58 PM   #34
328cic
My Ride: 2000 328ci
P0301
p1250
p0300
p1188
p0170
p0302
p0303
p1161
p0116
p0441
p1423
p1421
p0727
p1250
p0300
crankshaft sensor, fuel pump, starting problem
