Old 12-15-2013, 01:55 PM   #21
3 3 0 C i
My Ride: 528xi
Fuel pump -- again?
Hey jfoj thanks for the idea. I double checked the connection and it looked a little loose pulled it off put it back on and now the car is running. So the old pump must have been bad and the new pump is working now that I have it fully plugged in thank you all for your feedback.
2002 330Ci M Sport, 5-speed Manual
2013 528xi Premium, 8-speed Steptronic
3 3 0 C i is offline   Reply With Quote
Old 12-15-2013, 03:28 PM   #22
Alex323Ci
My Ride: M3 & 323Ci (sold)
oh that's good news. i figured jfol would be the go to guy on this
Old 02-08-2014, 09:09 AM   #23
3 3 0 C i
My Ride: 528xi
To update the thread for the dude who is going to search this on Google in three years, This happened again twice.
All when it got really cold. Really cold like -5F. Got fed up trying to fix it so I towed it On flatbed to the dealer; by the time it got to the dealer it was fine because it got bounced around on the truck which apparently freed up the brushes on the pump.
So I traded it in on an f10.
Thanks to everyone on e46fanatics. Even the douchebags.
See you on bimmer fest.
Yay for maintenance plan.
Old 02-08-2014, 09:36 AM   #24
jfoj
My Ride: 330CiC, M5, X5, E93
Sorry to hear you had more issues, sounds less likely the fuel pump and more an issue with the relay or some terminal somewhere being loose?
But yes, everything has a challenge as the temps drop very low, but should not have caused this type of problem.
Good luck with your new ride.
fuel pump, multimeter
