Any BMW 1999 BMW M3, Estoril/Black 5 speed, Full Dinan S3 package, mint - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars - Private
Old 12-12-2013, 07:11 PM   #1
///M3D
My Ride: 2006 BMW M3 ZCP
Thumbs Up 1999 BMW M3, Estoril/Black 5 speed, Full Dinan S3 package, mint
Car Specifications:
Year: 1999
Make: BMW
Model: M3
Type: Coupe
VIN: WBSBG9339XEY81091
Mileage: 85k
Price: $20,000/obo
Number of Owners: 4th Owner
Length of Current Ownership: ~3mo
Reason for Selling: Moving to E46 Chassis
Accidents: None
Title Status: Clear, Clean and in hand
Maintenance Records: Extensive, back to about 3600 mi/original owner
Exterior Trim: 335 - Estoril Blue Metallic
Interior Color: N5SW Black Leather
Original MSRP: $43,320
Production Date: 12/1998
In-Service Date: 02/23/199
Factory Options:
0095 CD Changer
0325 Rear Spoiler
0401 Steel Power Sunroof
0674 Harman/Kardon Premium Sound
0264 PIA CD Brkt Sedan/Coupe
0335 100% Options
0540 Cruise Control
0998 Buffer - Launch Supply
Original Dealer: Weatherford BMW
Production Statistics: 1/258 Estoril Blue Metalic/Black Leather/5 Speed M3 Coupes. No data on the production numbers for the Dinan S3. Source: Coupe Production Numbers
Pictures: 1999 BMW M3 DINAN S3
Car History:
The car is an original CA car. It was purchased in Berkeley, CA at Weatherford BMW. The original owner then took the car to Dinan in Mt View CA where the S3 package was installed on the car at 3600 miles. The car then moved down to San Diego with the 2nd owner where it stayed for about 70,000 miles. The 3rd owner purchased the car while living in Texas and the car was shipped out to Texas. The 3rd owner then moved to St. Louis and brought the car with him. Once in St Louis, he did not drive the car much at all, let alone in the winter and it shows. The car is completely rust free as you would expect from a n original CA car. The car was in St Louis approximately 1 year when I purchased it and brought it back home to CA.
Maintenance Summary:
Brake fluid: Bled @ 82250 miles, Motul fluid used
Shifter: New delrin oval carrier bushing, new OEM selector pivot, bearing bolt, gearshift rod joint, securing clips and plastic washers @ 82273 miles
Transmission fluid: 50/50 mix Redline MTL and Redline D4 @ 82407 miles
Rear shift arm bushings: OEM replaced @ 82407 miles
Cooling System: Aluminum thermostat housing, thermostat (88C), coolant flush @ 82407 miles
Air filter: Dinan D403-0300 @ 82432 miles
Mass Air Meter Boot: OEM @ 82,511 miles
Steering Rack: Rebuilt OEM, new inner and outer tie rods, new reservoir and clamps, new return line, flush fluid with Castrol Import ATF @ 82511 miles
AC: OEM compressor drive belt @ 82511 miles
Airbag Trim Cover: OEM @ 82511 miles
Seat Belt Cover: OEM @ 82517 miles
Battery: Bosch @ 82565 miles
Cowl Cover: OEM @ 82565 miles
Passenger Side Hood Strut: OEM @ 82770 miles
Power Steering Pump: Rebuilt @ 82770 miles
Oil Breather Line: Dinan line from oil separator to intake piping @ 82770 miles
Clutch: Clutch arm bushing (Delrin), OEM slave cylinder @ 82791 miles
Speaker: OEM HK driver side door midrange @ 82791 miles
Supercharger: Rebuilt, new Vibrant SS T-clamps on all intake piping, all vacuum lines and connectors for superchager, bypass valve (bosch), all oil return lines and clamps, crankcase vent hoses and clamps @ 82826 miles
Intake: Removed and cleaner, new gasket, cleaned IAT and new oring, clean idle air control valve and replaced piping, new injector orings, all vacuum lines,fittings and clamps from intake manifold to brake booster and bypass valve @ 82826 miles
Dipstick: Dipstick tube cleaned, new oring @ 82826 miles
VANOS: OEM oil feed pipe and all seal washers @ 82826 miles
Throttle Body: Cleaned, new gasket @ 82826 miles
Oil: Mobile 1 full synthetic, OEM filter @ 82892 miles
Cabin Air Filter: Bosch filter @ 82892 miles
Headlights: New OEM @ 82920 miles
Transmission: Replaced all 5 shift pins, bushings, springs, shift rod seal @ 82929 miles
Clutch: OEM Sachs clutch disc, pressure plate, throw out bearing, clutch fork pivot, bleed clutch @ 82929 miles
Catch Can: New Dinan oil vapor catch canister @ 82929 miles
Cooling System: OEM water pump @ 82973 miles
Brakes: Bleed brakes and clutch with Motul fluid @ 82973
Battery: Bosch @ 83258 miles
Modification Summary:
Dinan S3 Kit: Vortech supercharger with updated/upgraded pulley (340hp/ 307lb-ft), full S3 suspension with adjustable Koni dampers, free flowing exhaust, front and rear strut braces, fixed camber plates, performance engine software @ 3600 miles
Alarm: OEM alarm was added @ ~30000 miles
Brake lines: SS UUC @ 82250 miles
Clutch line: SS UUC @ 82250 miles
SSK: OEM Z3 short shifter @ 82273 miles
Engine Mount: UUC Poly mount @ 82312 miles
Transmission Mount: UUC Poly mount with cup enforcers @ 82312 miles
Bushings: UUC Poly Rear subframe and rear trailing arm bushings @ 82312 miles
Kidney Grill: Turner matte black @ 84181
Steering Wheel: Rewrapped to E9x dimensions @ 84218 miles
Shift Knob: OEM ZHP @ 84685 miles
Tires: Front tires BFgoodrich g-Force Sport Comp 2 @ 85116 miles
Current Condition:
Currently, the car is in excellent condition. There are no outstanding maintenance items, this is a turn key car. If I was going to keep the car the next item on my list would be to perform preventative maintenance on the brakes by replacing the rotors and pads. Currently, the brakes are in fine condition but I would rather replace them before they get to the point of requiring replacement. That is simply how I like to maintain my cars.
There are two notable scratches on the car. One on the bottom side of the driver side side view mirror. The other on the driverside rear quarter panel. See the pictures for full details.
The interior is in absolutely spectacular condition. It is very clean. Both vaders have intact bolsters with the drive side showing slightly more wear than the passenger side, as you would expect. However, the are no rips, tears or other material failures in either the driver side or passenger side bolsters.
FAQ:
Has the cooling system been replace?
Yes
What kind of tires and what is their condition?
BFGoodrich g-Force Sport Comp and they are nearly new
Does it have power seats?
No
Does it have heated seats?
No
Does it have a sunroof?
Yes
Have the RTABs been replace?
Yes
Has the car ever been in an accident?
No
Does the car have all the original body panels?
Yes this is a complete numbers matching car
Do you have the manuals?
Yes
Has the car been tracked?
I can only speak for myself and I have not tracked the car
Is the price firm or will you negotiate?
I am willing to work with a serious buyer.
Do you smoke, have kids or dogs that ride in the car?
No to all of the above. The interior is in excellent condition.
Who has done the work on the car?
During my ownership the only shop to touch the car has been Performance Technic
Can I get a PPI done?
Of course, but the cost is yours.
Will you ship the car?
Not a problem, but again, the cost is yours.
Has the CEL light come on for any reason?
No
Is this car SMOG legal in CA?
Yes it is. The Dinan S3 package comes complete with a CARB number
Does the engine burn more oil than a typical S52?
No it does not.
Has a leak down test ever been performed?
Yes it has and all cylinders were within 1-2% loss
Does the AC blow cold?
Yes
Have you taken the car to a dyno?
No
Do you have the Dinan serial number?
Per the sticker on the driver side strut tower D36 M3-013
Current: 2005 E46 ///M3 - SG | CIN, 1999 E36 ///M3/2/5 - TiAg | BLK, 1998 E36 ///M3/4/5 - Estoril | BLK
Previous: 2002 E39 ///M5 - TiAg | BLK, 2010 E92 ///M3 - LMB | BLK
, 2008 E90 ///M3 - IB | BLK , 2006 E46 ///M3 - IR | CIN | ZCP | 6MT, 2007 E90 335i
///M3D is offline   Reply With Quote
Old 12-12-2013, 07:20 PM   #2
olivierE46M3
My Ride: E46 M3 2003
Sweeeet ride!!!!!
olivierE46M3 is offline   Reply With Quote
Old 12-12-2013, 08:47 PM   #3
///M3D
Thanks!
Old 12-12-2013, 09:35 PM   #4
Crestwood1001
My Ride: 2001 325xi
Re: 1999 BMW M3, Estoril/Black 5 speed, Full Dinan S3 package, mint
Car is awesome keep it
Crestwood1001 is offline   Reply With Quote
Old 12-12-2013, 09:51 PM   #5
///M3D
I would if I could swing it
Old 12-14-2013, 04:14 PM   #6
///M3D
Link in first post updated with a ton (100+) of new photos taken today!
Old 12-14-2013, 10:07 PM   #7
kbee
My Ride: m3
pics in link are not working at this time.
kbee is offline   Reply With Quote
Old 12-14-2013, 11:32 PM   #8
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
link no workie
/_________\
O==[][]==O
Old 12-15-2013, 12:27 AM   #9
///M3D
Very odd...
Not sure what happened there but I updated the link and it is working for me. If the link is still not working let me know.
Old 12-15-2013, 12:29 AM   #10
330i ZHP
330i ZHP's Avatar
works now
/_________\
O==[][]==O
Old 12-15-2013, 12:32 AM   #11
330i ZHP
330i ZHP's Avatar
wow, stunning
/_________\
O==[][]==O
Old 12-15-2013, 12:35 AM   #12
///M3D
Car is in outstanding condition
Old 12-18-2013, 11:03 AM   #13
///M3D
bump!
Old 12-22-2013, 01:13 PM   #14
///M3D
bump!
Old 12-23-2013, 07:15 AM   #15
sm32589g
My Ride: 1999 323is
about 7k too much :/
sm32589g is offline   Reply With Quote
Old 12-23-2013, 07:25 AM   #16
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Wow. That's E46M money, but for the right buyer it's quite the car.
Do you ride a sportbike?
Old 12-23-2013, 10:17 AM   #17
///M3D
Thanks, it is a lot of car for the money.
Old 12-25-2013, 11:10 AM   #18
///M3D
bump
Old 12-27-2013, 10:12 AM   #19
Act of God
My Ride: Longboard
Send a message via ICQ to Act of God Send a message via AIM to Act of God Send a message via Yahoo to Act of God
dayum!
"A liberal will cut off your leg to hand you a crutch." - Unknown
Act of God is offline   Reply With Quote
Old 12-27-2013, 10:45 AM   #20
///M3D
Indeed sir!
dinan, e36, estoril, m3, s3
