Old 12-21-2013, 07:42 PM   #1
yoyomin
My Ride: 2002 330i
Huge coolant leak after going over snow bank
When I was backing into my driveway there's about 1 foot of snow in front of the house. Right after the front of the car went over the snow bank I noticed white steam coming out from under the hood. After shutting off the car I poped the hood open and it's pretty clear that the cooling system just exploded
I'm wondering where is the most likely place that is leaking? I was trying to find any place near the bottom that is leaking but the freezing rain and cold is not helping. I will try to check again tomorrow, any suggestions would be great!
yoyomin is offline   Reply With Quote
Old 12-21-2013, 08:22 PM   #2
jdstrickland
My Ride: '94 325iC & '00 323i
OMG!
Most likely place? Impossible to say. You have to look for carnage.
Old 12-21-2013, 09:04 PM   #3
davidmaria1
My Ride: 2001 330i
The radiator is only hard mounted at the top, not at the bottom. If the car came down on the shield where it slips under the bumper cover, then, yes, something happened! Have a drink with your Sunday brunch before you pop the hood.
davidmaria1 is offline   Reply With Quote
Old 12-21-2013, 09:53 PM   #4
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
It's prolly just snow evaporating off the hot exhaust...
Cavi Mike is offline   Reply With Quote
Old 12-21-2013, 10:06 PM   #5
yoyomin
My Ride: 2002 330i
dammit hope I didn't destroy the radiator. I remember the steam was coming from underneath the expansion tank. Hopefully it's just a hose.
Old 12-21-2013, 10:08 PM   #6
yoyomin
My Ride: 2002 330i
I certainly hope that you are right... but I'm 100% sure it was coolant. The smell and the fact that the coolant light was on 5min later when I put the key to position 2.
Old 12-21-2013, 10:17 PM   #7
BlazingWildBill
My Ride: Ferg 328Ci
Re: Huge coolant leak after going over snow bank
Check the part that connects on the lower radiator driver side. I have had that come off before. Also try lower radiator hose.
Post Count:666Sig thanks to Big Rick
BlazingWildBill is offline   Reply With Quote
Old 12-21-2013, 10:39 PM   #8
jclip
Location: Founder of the uber-rare body color roof club
My Ride: 06 m3, 01 325
Driver or passenger side? If it's the driver side, good chance you broke the expansion tank mounting bracket. The bracket houses the drain tube for the expansion tank, it's a possibility...
jclip is offline   Reply With Quote
Old 12-21-2013, 10:55 PM   #9
yoyomin
My Ride: 2002 330i
fingers corssed, hope it's just detached hose...
It's driver's side I think. Most of steam came from underneath the expansion tank so you might be right. I'll report back tomorrow after tracing down the leak with some coolant.
Old 12-22-2013, 12:53 AM   #10
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
does yoru car have the plastic undertray?
/_________\
O==[][]==O
Old 12-22-2013, 01:07 AM   #11
yoyomin
My Ride: 2002 330i
Yeah I have the shield, and after the leak I checked and it's still held in place by the screws to the front bumper. Honestly I didn't feel anything when the car went over the snow. The shield probably got pushed upward and did some damage...
Old 12-22-2013, 01:09 AM   #12
VishTheFish
My Ride: Ex M54B30 ZHP
if the undertray pushed up that hard then it should be falling off and not intact
VishTheFish is offline   Reply With Quote
Old 12-22-2013, 01:13 AM   #13
330i ZHP
330i ZHP's Avatar
if the tray pushed up - the most likely cuprite would be the drain on the bottom of the ET
/_________\
O==[][]==O
Old 12-25-2013, 02:28 PM   #14
yoyomin
My Ride: 2002 330i
It finally stopped snowing today. Turns out to be the expansion tank:
Old 12-25-2013, 02:43 PM   #15
jdstrickland
Holy cow! Is that a crack that runs from top to bottom?
Old 12-25-2013, 02:44 PM   #16
davidmaria1
My Ride: 2001 330i
It could have been worse. Hopefully, that is the extent of the damage.
coolant, cooling
