Sponsored by BimmerWorld
Old 01-11-2014, 03:14 AM   #1
DAT E46
My Ride: E46 coupe
H&R Sport Springs vs Tein S-Tech Springs
Hey Guys, I wanted to ask should I go with H&R Sport Springs or Tein S-Tech Springs?
and also how do both handle on speedbumps? would I have to go sideways to avoid scrapping with a 325ci? lol
DAT E46 is offline   Reply With Quote
Old 01-11-2014, 03:32 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
You should do a search on the "Tein S Tech" springs to see if any forum member has them, then PM them to see what they think. The vast majority of E46F members run either H&R (Sport or Race) or Eibach (Pro kit or Sportline) springs, both of these brands are very well proven on the BMW chassis.
As to speed bumps, you should be fine with either the H&R Sports or the Eibach Pro Kit springs.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 01-11-2014, 05:46 PM   #3
DAT E46
My Ride: E46 coupe
Good luck.
alright, Thanks! I appreciate the help man
Alpine White 2004 M3 // Volks TE37 // ST Coilovers // Active Autowerke Exhaust // K&N Intake
e46, springs
