P1523 fault code - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-19-2014, 09:30 AM   #1
mmc545
My Ride: 328Ci; '01 330Cic
P1523 fault code
2000 328Ci Auto 130K
Driving to work the other morning my SES light came on, had the code read as
P1523 - 'A' Camshaft Position Actuator Signal Low (Bank 1) (M52: 'B' Camshaft Position Actuator Tight or Jammed).
I found a few posts about this, the best answer seemed to suggest vanos seals. But I used the beisan kit about 2 years ago and have had no issues since. Im not sure this is a seal issue.
I've had a pesky valve cover gasket leak for most of the winter, just been too cold to replace. It was a pretty slow leak, and i've kept plenty of oil in the car so I didn't really think it was a big deal.
The same morning the light popped on, I noticed a high pitched whine coming from the vanos area while the car was at idle, but once the ambient temperature got above 50 the whine went away.
Other than the noise and light, the car seems to run fine: steady idle, same performance, same fuel economy as before the light.
As far as cam shaft sensors and o2 sensors, they would be original, ie have not been replaced since new.
The plan was to swap the valve cover gasket this weekend, but now i've got to deal with this code. Could it be as simple as leaking oil from the vcg getting into the vanos?
mmc545 is offline   Reply With Quote
Old 03-05-2014, 08:22 AM   #2
Kingnog
My Ride: 1999 323i *sport*
Did you ever figure this out? I'm having the same issue, including a previous valve cover gasket leak that I "fixed" with silicone...
lll
Kingnog is offline   Reply With Quote
Old 03-05-2014, 09:28 AM   #3
scarede46er
My Ride: 2001 BMW 325i ZSP
Change your can sensor (intake). Don't know how much more descriptive an error msg could be!
p1523, ses, vanos
