Please help me with my 325ci!!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 03-07-2014, 08:25 PM   #1
blindman23
My Ride: 325ci
hello guys I'm new here and I really need your help. My 2001 325ci traction light and hand brake light are yellow, it just started happening today. Now when I attempt turn it on it has trouble starting like it takes about 2-3 seconds to start. Please guys help me out I greatly appreciate it!@!@!@
I also need to replace my spark plugs and ignition coil 1 because of misfire but I've been having that for month and never had that issue incase that helps!!!
blindman23 is offline   Reply With Quote
Old 03-07-2014, 08:51 PM   #2
David McMahon
My Ride: '99 E38 740iL
You need to find what the codes mean. You mention the coil 1 misfire, so I assume you found that out by reading codes before?
David McMahon is offline   Reply With Quote
Old 03-07-2014, 08:56 PM   #3
blindman23
My Ride: 325ci
Yes but that was way before this problem came about. I've read similar posts but none of them had that same start up issue I'm having.. It's frustrating..
Old 03-07-2014, 09:08 PM   #4
David McMahon
After reading the forums for over a year I think the most common causes are
1, Bad battery, try an overnight charge
2, Fuel pump / filter, if not done recently they are worth buying anyway, keep old fuel pump as a spare.
3, loose electrical connectors, check/clean.
4, Maybe bad starter, changing them is supposed to be difficult, not done it yet myself.
Now this only a list from memory of no start/bad start threads.
If the Yellow brake light is lit up for a "proper" reason, speed sensors come up often, some advise cleaning them, some advise they are "hall effect" and cleaning makes no difference!
Old 03-07-2014, 09:30 PM   #5
blindman23
My Ride: 325ci
Man to be honest I probably won't have the money to replace everything until 1-2 months from now. Do you think the car will be ok till then?
Old 03-07-2014, 10:22 PM   #6
lszlszx
My Ride: 1.8T, XC70
Replace the bad coil at least, that may improve your hard start problem.
You'll have to scan with a BMW specific scanner to find out about the traction light.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-08-2014, 08:00 AM   #7
blindman23
My Ride: 325ci
Yeah I'm going to try and do that this week, I hope that's the problem.
325ci, bmw, issue
