Lower Control Arm, Rear Shocks & Differential Oil, oh my. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-21-2014, 12:42 PM   #1
comova
My Ride: Silver 325Cic
Before starting this weekend's DIY (if parts arrive) I wanted to ask the forum a couple quick ones:
1. Any quick tips on removing broken lower control arm bolt (the one blocked by differential)
2. First time doing rear shocks, anything I should look out for?
and
3. Should I change the differential oil while I am down there?
I don't think it's ever been replaced, well not by me anyway...138K on the odometer.
Wish me luck.
"The problem with the designated driver program, it's not a desirable job, but if you ever get sucked into doing it, have fun with it. At the end of the night, drop them off at the wrong house." -Jeff Foxworthy
comova is offline   Reply With Quote
Old 03-22-2014, 09:09 AM   #2
markusmarkus
My Ride: 2001 330Ci
3. Yes! I use Redline 75w-90 for non-limited slip differentials. You'll need a quart but be careful when filling. Why? The differential takes exactly a quart of lube! Also, remove the FILL plug FIRST. Why? If you drain the differential and can't get the fill plug out you're stuck!!!! After that many miles that fluid will be nasty.
2. Change the upper shock mounts when changing the shocks. Some owners buy the shock mounts from a Z3 as they are more robust. I use the ones for my car (2001 330Ci).
1. Removing a broken bolt isn't too hard. Which bolt is broken as the rear LCA has several bolts attached to it.
Old 03-22-2014, 10:03 AM   #3
hvactim
My Ride: e46
Which z3 upper shock mount
hvactim is offline   Reply With Quote
Old 03-22-2014, 10:21 AM   #4
comova
Sorry MarkusMarkus, the actual control "arm" broken, not the upper bolt. I loosened the differential to get it out, sounded easier in the DIY.
Update
New control arms are in the car but have to speak with local mechanic about getting everything torqued down. My torque wrench doesn't go up to the 110 Nm the front differential bushings & control arm bolts need. :/
Still waiting on hardware (shocks)
Thanks for the tip on differential.
~CV
Old 03-22-2014, 10:39 AM   #5
cvx5832
My Ride: 325Ci, 325Cic, C300
Just get yourself another torque wrench rather than taking it to a mechanic. They're not expensive at all.
cvx5832 is offline   Reply With Quote
Old 03-22-2014, 11:22 AM   #6
comova
Any suggestion on a good one (that's not too expensive)?
This $100 job is starting to get 'spendy, I still need to get the alignment done.
Old 03-22-2014, 11:43 AM   #7
yoyomin
My Ride: 2002 330i
You could get those electronic torque adapters for under $100. The torque range on those is really wide. I have the AC delco one and I've been using it for a while.
yoyomin is offline   Reply With Quote
differential, lower control arm, shocks, suspension
