Old 03-24-2014, 03:45 PM   #1
comova
My Ride: Silver 325Cic
Question Springs: 2 replace or not 2 replace = ?
I am "rejuvenating" my suspension and was wondering how can I tell (diagnose) if my springs needs replacing? Do they those their "springy-ness"? I am on a budget and rather not spend money I don't have on something that is still good.
My 1st DIY was (last weekend's) rear lower control arm replacement, both. The right side broke completely off, & the left was a little tweaked.
2nd DIY: I am replacing my rear shocks this weekend and then ordering parts for front struts $500 in parts (ouch!)
3rd will probably be some combination of bushings as they all are beyond past due. But front control arm for sure.
I am on a budget. Car has 138k miles. I would love to keep working on it but the price tag seems to be skyrocketing the older it gets.
ALL advice is welcomed.
Cheers! ~CV
"The problem with the designated driver program, it's not a desirable job, but if you ever get sucked into doing it, have fun with it. At the end of the night, drop them off at the wrong house." -Jeff Foxworthy
comova is offline   Reply With Quote
Old 03-24-2014, 03:48 PM   #2
orb
orb's Avatar
My Ride: 325Ci
Really no need to unless they're broken, or the car has 200k.
orb is offline   Reply With Quote
Old 03-24-2014, 04:03 PM   #3
Sansho
My Ride: 2001 325i
It's the springs that hold the car at it's height. Bentley manual page 300-21 has all the measurements to see if your car is sitting at spec, as measured from the fender lip to the bottom of the wheel rim. If you find much difference from stock, and assume you don't have a user lowered suspension already, then replace the spring(s). You can buy single replacement springs from BMW.
In front, with 16" tires and standard suspension, it's 589mm or 23.19 in. With sport suspension, it's 574mm or 22.59". If 17" rims and standard suspension it's 604mm or 23.77 in. With sports suspension it's 589mm or 23.19 inch.
In the rear, 16" rims with standard suspension is 555mm or 21.85 in and sport suspension 539mm or 21.22 inch. With 17" rims and standard suspension it's 570mm or 22.44 inch and sports suspension is 554mm or 21.81 inch.
Sansho is offline   Reply With Quote
Old 03-24-2014, 04:08 PM   #4
bee-em-dougle-u
My Ride: 2002 BMW 325i
I'd say inspect the springs carefully, and reuse them if there are no visible cracks/flaws/ corrosion. If it's a Left Coast car, corrosion is probably not an issue.
2002 BMW 325i sedan
Manual gearbox, but of course!
Tasteful mods
128K miles and counting
bee-em-dougle-u is offline   Reply With Quote
Old 03-24-2014, 04:46 PM   #5
BMWespresso
My Ride: 2005 325CI
not 2
BMWespresso is offline   Reply With Quote
Old 03-24-2014, 05:14 PM   #6
racin366
My Ride: 04 325ci
Springs sometimes break, but otherwise they don't wear out in any meaningful time frame and shouldn't need replacing.
racin366 is offline   Reply With Quote
Old 03-24-2014, 06:02 PM   #7
comova
Thanks a ton fellow DIYers!
Old 03-24-2014, 06:22 PM   #8
Cowspoo
My Ride: 328Ci
So my springs aren't circular at the base, they're sort of square and hanging off the edge of the strut mount. If they're strangely bent - they need replacing?
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 03-24-2014, 06:31 PM   #9
Swater330i
My Ride: 2003 BMW 330i 5MT
all 4
Originally Posted by phenom323ci View Post
I am going to install M3 fender grill on my 323ci.
Originally Posted by futureSubie View Post
IMO, the euro clear corners looks too aftermarket/ricey.
Originally Posted by Davconelectric View Post
This 323 would most likely handle and drive better than a stock e46 m3.
Swater330i is offline   Reply With Quote
bushings, shocks, springs, struts, suspension
