Old 04-08-2014, 03:45 PM   #1
rockyiiibalboa
My Ride: 1999 323i 2.5l
Exclamation e46 1999 323ci tilt reverse wont tilt backup
hi guys been a while since being on here just recently brought my 4th bmw 99 323ci erm basically im stumped by this and not read any forums with my problem so here goes and if any one can answer would be apperiated
here is the prob
basically drive a uk standard coupe with the mirror switch selected to the drivers side to engage reverse tilt and mirror tilts as it should yeah all good but as soon as i take car out of reverse the mirror doesnt come back up just stays in the tilted position and have to manully adjust which is pretty annoying, however this is were its strange if i adjust the mirror pointing away from the car as far out as it can go and engage reverse itll tilt and come back up but as soon as i adjust the mirror properly where i need it itll tilt but stays down and noticed it doesnt adjust with the memory setting on the seat unless the mirrors pointing well away from the car again really weird is there a way to sort this ? and not intrested in going to the dealers either
cheers lee
rockyiiibalboa is offline   Reply With Quote
Old 04-08-2014, 04:20 PM   #2
swaggerwagon
My Ride: 2005 330i
sounds like the mirror Potentiometer is bad. it will prevent the mirror from tilting back up. it is simple to replace.
330i ZHP
3 Pedals FTW
BMW level 2 Tech
Ebay headers | Long tube CAI | modbargains ///M pedal covers | SS clutch line | CDV removed | Turner camber arms | Meyle HD FCABs | uuc poly motor/trans mounts | Eurospec Muffler | Clutch masters Stage 2 with aluminum flywheel | Coilover kit | CSL front bumper | Z4m shift lever | VISracing CF hood | Depo HID w/CCFL halo rings
swaggerwagon is offline   Reply With Quote
Old 04-08-2014, 04:24 PM   #3
rockyiiibalboa
ohhh ok kool whats that part may i ask ? easy to fit? and thank you for your reply
cheers lee
Old 04-08-2014, 05:31 PM   #4
rockyiiibalboa
can anyone shed any light on this part or a photo so i know what im looking for have tried googling but not alots coming up thanks
lee
323ci, coupe, mirror, reverse, tilt
