Old 04-19-2014, 05:03 PM   #1
KNGJN
My Ride: Ram 1500
Looking at an E46 with a blown tranny...
New here by the way! Never owned a BMW before, but looking at the E46's has gotten me all fuzzy inside and I really want to get into one.
i looked over an E46 330i with a blown tranny and 107k on the motor. They called and want me to come pick it up later today. It was an automatic, but I want to swap a 5 speed in it regardless.
If I buy the car for $2500 what can I expect to spend regarding the 5 speed swap? Will the swap be worth the buy?
KNGJN is offline   Reply With Quote
Old 04-19-2014, 05:37 PM   #2
dmarkle
My Ride: 2002 330Ci
Seems like a lot to me, unless the body is impeccably clean and you know for a solid fact that the engine is good, and that it's had all of its other maintenance done on it. Of course, if an automatic trans is "blown" it might be because people failed to do the proper maintenance on it, and that might not be a good sign.
dmarkle is offline   Reply With Quote
Old 04-19-2014, 05:41 PM   #3
KNGJN
My Ride: Ram 1500
That's what I'm afraid of. I don't know how else to get that car for that kind of deal at 107k. The body has very minor damage. I know cars in general, I just don't know much about BMW's or E46's. The motor runs solid, we stressed it a bit, and it works, I just don't want to go over the value of the car in the end.
Old 04-19-2014, 05:47 PM   #4
WDE46
My Ride: '13 128i, '04 330Ci
That's pretty cheap assuming that's the only thing wrong with the car. I mean worst case with this seems to be a part-out and you'll get the money back easily.
A transmission swap will cost you about $1000-2000 depending on parts sourcing, and you may or may not want to swap in the lower ratio diff from the manual as well.
Transmission $500-700
Clutch and Flywheel $600
Driveshaft $150-200
Guibo $70
CSB $70
Hardware $30-50
Clutch/Brake Pedal set $150-200
Slave cylinder ???
Trans mounts
rear main seal (should do it when the tranny is off!)
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-19-2014, 05:50 PM   #5
KNGJN
My Ride: Ram 1500
Okay awesome, that was what I was hoping to hear, any other thoughts?
Old 04-19-2014, 05:55 PM   #6
cvx5832
My Ride: 325Ci, 325Cic, C300
With a neglected E46, and there's a lot of them out there, it's very easy to exceed the value of the vehicle when getting it up-to-date. By the time you've replaced the motor on that one you're looking at, your spending has just begun.
Look for something else.
cvx5832 is offline   Reply With Quote
Old 04-19-2014, 05:56 PM   #7
KNGJN
My Ride: Ram 1500
I'm not looking to replace the motor, just the tranny
Old 04-19-2014, 05:56 PM   #8
WDE46
Besides your swap, there will be a lot of other necessary maintenance. Look around the forums for that. Another $1000-2000 should cover the essentials.
Old 04-19-2014, 05:57 PM   #9
WDE46
Who said it needs a new motor?
Old 04-19-2014, 06:12 PM   #10
KNGJN
My Ride: Ram 1500
So whats the verdict?
Old 04-19-2014, 06:15 PM   #11
ReIntegration
My Ride: 2003 BMW 330Ci
Send a message via AIM to ReIntegration
Can you post some pictures of it if you can? What color is it? You said 330i so it's a 4 door right?
']['|R(G
Wernher Von Braun
2001 330Ci (My uncle was the original owner then given to me as a secondary to my 03)(Sold)(Kept younger brother)
2003 330Ci (Current & original owner - Born on 1.10.03)(Had it since new born. Delivered from Regensburg on 2.24.03)
Originally Posted by Mordecai
Ready to get destroyed?
ReIntegration is offline   Reply With Quote
Old 04-19-2014, 06:19 PM   #12
KNGJN
My Ride: Ram 1500
yeah its a 4 door, black on black, here it is -> ( http://newyork.craigslist.org/que/cto/4424162990.html )
Old 04-19-2014, 06:24 PM   #13
lszlszx
My Ride: 1.8T, XC70
If stick shift are hard to find in your area, your budget is at least $6000 and you don't mind working on it for a couple of months until it's sorted, go for it!
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-19-2014, 06:26 PM   #14
WDE46
I'm not gonna tell you to buy it or not. I haven't seen it in person or heard it run, etc. I'm just here to tell you what I know about tranny swap prices and a way out if it goes wrong (part out).
Old 04-19-2014, 06:28 PM   #15
My Ride: Lexus
Driveshaft $150-200
Guibo $70
CSB $70
Hardware $30-50
Slave cylinder ???
Trans mounts
What BMW diff would be lower ratio than a 2.93??? Why would he want to swap the diff already in his automatic equipped 330 (which is a 3.38?) just curious
Old 04-19-2014, 06:28 PM   #16
WDE46
I looked at the pics. It looks fairly clean but keep in mind it has the DSC light on. That may indicate other problems besides the transmission. Also it doesn't have the sports package.
If you could get someone with a BMW Scanner 1.4.0 to read the error codes, you could make a better decision.
Old 04-19-2014, 06:37 PM   #17
KNGJN
My Ride: Ram 1500
The DSC light to my knowledge is a brake problem? Right? I'm incredibly conflicted... "To buy or not to buy"
My goal here is to build myself a 330i to take to local autocross events, and have a little fun sliding around in, nothing crazy. My budget is approx $6000 and I'm more than happy to DIY this build.
I really just don't want to buy a car that I'd be in over my budget with.
Old 04-19-2014, 06:44 PM   #18
WDE46
When did I say there was a lower ratio than 2.93? I was saying he could opt to swap the lower ratio diff found in manual cars. Lower as in lower relative to the diff that is currently in the car. And he might consider that if he wants to replicate a stock manual E46.
DSC light can be many, many things.
You can probably do it just fine with that budget.
Old 04-19-2014, 06:45 PM   #19
ReIntegration
Is you budget about $6000 after hypothetically you buy the car or before? Cause if you have $6000 left over after you buy the car then yeah buy it and make it in to a cool project. It is in decent shape just proberly the previous owner beat the crap out of it cause 107k is a little low for a transmission of that year to go.
']['|R(G
Wernher Von Braun
Old 04-19-2014, 06:47 PM   #20
KNGJN
My Ride: Ram 1500
6k not including the price of the car, and I had a similar fear about the tranny dying at 107k.
330i, budget, manual, swap
