Differential help - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-12-2014, 07:14 PM   #1
Swoodford58
My Ride: 325i
Differential help
Hi I am a new bmw owner as well as new member to the forum, I own a 03 325i 5 speed, and am in need of advice, I'd like to add an LSD but I'm not sure of which kind to use, an m3 dif? Please help and thanks!
Swoodford58 is offline   Reply With Quote
Old 05-12-2014, 07:19 PM   #2
Llink78
My Ride: 2002 330i
M3 diff is the cheapest if you do all the work yourself, you need the rear subframe, diff, control arms, special driveshaft ( bc you have a sedan). But the ratio is way off for a 5 speed. Buying a 6 speed transmission to pair with it would put your swap around $2,200.00. Of you can contact the guy on here who retrofits bmw LSD's into the e46 housing for a direct plug and play set up (that will cost you around $1000) or go aftermarket and spend 1200-2000 but is not plug and play and you will need someone to install in your diff housing. Also use the search function. Someone once a week asked this on here.
234HP/197TQ Just bolt ons :) New Numbers Coming Soon!
Llink78 is offline   Reply With Quote
Old 05-12-2014, 07:30 PM   #3
Rob43
My Ride: 03 331Ci 5spd R1200R
Realistically, plan on spending about $1800 to $2000 installed for a LSD.
Go to the Driveline sub forum and start searching, lots of great info there.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 05-12-2014, 07:44 PM   #4
Stickbuilder
My Ride: Touring, and others
You need a limited slip differential on an underpowered family car why? It's not as though you are going to boil the hides off the car.
[/SIGPIC]I'm fluent in 3 languages:
English
Sarcasm
Profanity
Stickbuilder is offline   Reply With Quote
Old 05-12-2014, 08:06 PM   #5
lszlszx
My Ride: 1.8T, XC70
It can help to get traction on slippery road surface, but not worth it for $2000.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-12-2014, 08:11 PM   #6
mjpgolf1
My Ride: 00 328i,05 745,03 X5
+1.
OP we are all here for different reasons and we all have different opinions but as one of the older more experienced BMW owners let me try to talk some sense into you.
Being a new owner I'm sure you are excited and I'm sure you have a million different ideas running thru your head as to things you want to do to the car. This is only natural. However let me explain that first and foremost if you just bought the car there are several better ways to spend that $2000. These cars require quite a lot of maintenance to stay running tip top and to ensure that you have a reliable car. There are countless people like yourself on here that jump the gun and spend a bunch of cash modding their newly acquired BMW only to end up having nothing but problems with repairs and breakdowns. Some are serious enough to take out the entire motor.
My suggestion would be to hold off and do some research about the car you just bought. Get to know the items that require attention and make yourself a checklist. You will feel so much better about your car knowing that you are doing the responsible thing and making sure that it's running and performing as it should. Don't start chopping the car up to add unnecessary items to it. Not to mention the car you bought isn't even fast enough to have very much fun with a LSD.
If you want a sports car then set yourself a goal and save your money. You bought a luxury car with some performance characteristics but it's far from a sports car. Don't be like most other irresponsible kids on this site and start modding a car that runs and drives half assed. Just because you bought a car with a BMW logo on the hood doesn't mean it's the "ultimate driving machine" just yet. Spend the money refreshing what came on the car and get it back to its glory. You will be glad you did in the end. Good luck.
mjpgolf1 is offline   Reply With Quote
Old 05-12-2014, 08:34 PM   #7
Dirty-330
My Ride: 330ci,325xi,m3c
Originally Posted by mjpgolf1 View Post
+1.
Chuch!
Dirty-330 is offline   Reply With Quote
Old 05-13-2014, 03:37 PM   #8
Swoodford58
My Ride: 325i
+1.
Honestly that is some great insight , that has actually changed my mind since what you said made perfect sense, thanks for yr advice!
Old 05-13-2014, 04:24 PM   #9
Alex323Ci
My Ride: M3 & 323Ci (sold)
probably the same reason BMW put these in the E30 325is
325i, differential, lsd, manual
