///M3 Forum
Old 07-10-2015, 06:42 PM   #21
deephouse
My Ride: E46 M3
Unhappy
Originally Posted by joeysm3 View Post
Im telling u how to do it. Iv done it before for gear position sensor..
I know it's an old thread, but will a bad GPS cause your car not to start? My shop suggests that this could've happened to my car due to a bad GPS causing car to think the gear is not in N mode. My car primes, starter motor, and battery were installed as well. Now we've changed to a new GPS, but the car still isn't starting... wondering if it has to go through "reset" for GPS to recognize correct gear position.
deephouse is offline   Reply With Quote
Old 07-12-2015, 11:23 AM   #22
Commando
My Ride: '02 325Ci MT '04 M3
As said previously you will need to do the adaptations if you remove the GPS. If you have N or 0 on the display the car thinks its in neutral. If the N or 0 is flashing it may be the safety switches. Don't forget a foot on the brake.
Commando is offline   Reply With Quote
Old 07-12-2015, 01:02 PM   #23
deephouse
My Ride: E46 M3
I sure hope it's just the adaptations. Next up would be the pump if this wont fix..
Thanks for the info.
Old 07-16-2015, 09:07 PM   #24
cmstrilchuk
My Ride: 06 M3 ZCP
If you've had components changed double check your electrical connections too. A couple weeks after a pump change my car went to limp mode, turned out the multi pin connector wasn't fully seated and the intermittent connection threw faults at the DME. If you have SMG I think having a laptop and GT1 / INPA is essential to finding issues and clearing codes on your own.
cmstrilchuk is offline   Reply With Quote
Old 07-16-2015, 09:20 PM   #25
m3e46freak
My Ride: m Twee lol
if it wasnt said before, reset the teach in points
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 05-17-2016, 10:06 AM   #26
yan_j
My Ride: 2004 BMW E46 M3
Hey there, I realize this is an old thread but I just got my GPS replaced along with a new compression spring (that was broken). Now when I up shift I get a slight slurr in every gear when I am pedal to the metal.
I have the Autoengenuity tool and have ran a:
- teach in clutch characteristic curve
- tech in clutch slip point
- offset longitudinal sensor reset
- reset clutch values
It has only been 1 day since I performed the resets but I still have the slurr when upshifting. Please help!!
yan_j is offline   Reply With Quote
Old 05-17-2016, 10:27 AM   #27
joeysm3
My Ride: ///M3 02
Have u done an smg reset? If not here is the instructions to do so.
Drive to approx 30/40mph, stick her into neutral when the screen shows gear '0' or 'N' hold both paddles together for 3-5 secs. Stick her back in to gear and your SMG will be reset.
joeysm3 is offline   Reply With Quote
Old 05-17-2016, 10:47 AM   #28
yan_j
Yes, I have tried that as well. Perhaps I should drive it hard for a week and see if it adapts? I'm thinking I need to perform a full transmission adaptation ?
Sent from my Nexus 6 using Tapatalk
e46, m3, slipping, slur, smg
