Engine & Performance
Old 05-14-2014, 02:02 PM   #1
gaffycool1
My Ride: 325ci bmw msport e46
Post BMW E46/E36 complete turbo charger kit for sale and manifold!!! bargain, rare sale
FOR SALE - BMW E46, E36, 323, 325, 328, 330 FULL COMPLETE TURBO KIT
SHOULD FIT ALL 3 SERIES E46 AND E36 WITH 6 CYLINDER ENGINES/MANIFOLDS
For sale is a complete turbo kit for a BMW e46 and e36. It is brand new and never used or bolted on. Genuine reason for sale. This was purchased originally for my BMW E46 325ci 2001, but since then I have to pay my rent and therefore after spending over a thousand on the kit, I am regrettably going to have to sell it.
This kit is a complete, including extra bits that I purchased just for the car. Unlike the universal kits that are being sold on ebay, some parts in this kit were purchased separately to make sure they would fit the BMW and therefore cost me alot, such as the manifold.
It should fit all E46's and all E36's with a 6 cylinder engine as the manifolds are the same on both cars. The kit may also fit other cars, but you will need a different turbo exhaust manifold if that is the case.
list of what's included:
T3/T4 Garret Turbo Charger
E46 V6 cast manifold (EM030)
2.5" Intercooler 550 x 140x65mm
AIR FILTER (in red)
Air Breather Valve Cover Filter 50mmx35mmx25mm
MANUAL BOOST CONTROLLER (colour blue )
19 row oil cooler (comes with all the piping, and washers etc), blue colour.
Oil Relocation Kit
Oil Feed Line Kit
2.5"TURBO INTERCOOLER PIPE PIPING DIY KIT 57MM SILICONE
SUPER SQV BYPASS DUMP BLOW OFF VALVE BOV KIT (color silver)
Turbo Timer (color Silver )
Oil Catch Tank
38mm External Turbo Wastegate (silver)
2 of 10" Fan (may not be needed for the BMW but still provided).
1 Heat wrap (black)
Fuel Pressure Regulator
extra bits that I purchased seperately:
Turbo exhaust Manifold Steel Gasket
Turbo Manifold 5 bolt gasket for the turbo
Turbo Manifold 5 bolt steel gasket plate (to weld your exhaust onto)
1 meter of silicone piping 4mm, (blue colour) x 3 (so 3 meters in total)
3 x t piece (these are very important and can be used with piping to hook up to gauges for the interior).
For the extra bits, I spent 150 alone as they were very hard to get, most of the parts coming from Germany.
If there are any more items that I have missed, I will add them to the list.
no instructions are provided so professional fitting is required as some pipes may need cutting and welding.
images will be up tonight or tomorrow, I have a generic image at the moment to show what the kit looks like (does not show the extra parts list).
offers welcome, pm me.
ONLY 600 !!!
No postage and local pickup only from pe29 area in cambridgeshire, cash on collection
GRAB A BARGAIN, CHEAPEST ON THE INTERNET!! EVEN EBAY!! FIRST TO SEE WILL BUY!
any questions please get in touch
thanks
gaffycool1 is offline   Reply With Quote
Old 05-14-2014, 02:29 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
AIR FILTER (in red)
Oil Relocation Kit
Oil Feed Line Kit
Oil Catch Tank
1 Heat wrap (black)
ONLY 600 !!!
thanks
OP,
You say this Turbo Kit is "Complete", if so where is the TUNE ?
I don't see any mention of the tune, without a perfect working tune all you have is a box of parts.
Please show us the Tune, only then will this be a Complete Kit.
GLWS
SUMMIT POINT WV 1:24:229 SCCA
Old 05-14-2014, 02:58 PM   #3
gaffycool1
Originally Posted by Rob43 View Post
OP,
GLWS
It is a brand new turbo kit for sale, I didn't say it was fitted on a car? So why would I have a tune if it's just a turbo kit not fitted to a car? Not sure what your trying to get at
Old 05-14-2014, 03:08 PM   #4
Rob43
Rob43's Avatar
That's fine.
Understand when you say "Complete", this means to anyone reading this that it would work once it was installed. But your kit won't, because it doesn't have a tune which means it's not complete.
Old 05-14-2014, 03:27 PM   #5
ReIntegration
My Ride: 2003 BMW 330Ci
Send a message via AIM to ReIntegration
"No postage and local pickup only"
You should post this in the UK section only since you are not shipping/postage.
']['|R(G
Wernher Von Braun
2001 330Ci (My uncle was the original owner then given to me as a secondary to my 03)(Sold)(Kept younger brother)
2003 330Ci (Current & original owner - Born on 1.10.03)(Had it since new born. Delivered from Regensburg on 2.24.03)
Originally Posted by Mordecai
Ready to get destroyed?
ReIntegration is offline   Reply With Quote
Old 05-14-2014, 04:22 PM   #6
gaffycool1
That's fine.
Yes it understand what your saying, just to clarify then it's a turbo kit which will fit onto the bmw, no ecu is supplied
Old 05-14-2014, 04:23 PM   #7
gaffycool1
I'm not sure how to do that, I can post if the postage is paid but it will be in the excess of around 80/$140 I would have thought
Old 05-16-2014, 06:25 AM   #8
gaffycool1
can admin delete thread. kit has now been sold
thanks
Old 05-16-2014, 09:03 AM   #9
323i E46
My Ride: 2000 323i
I always thought that the 323/328 manifold was different from the 325/330 manifold. You might want to look into that before you say it will fit on any e46.
Edit: Should have read the last post. Sorry
323i E46 is offline   Reply With Quote
e46, manifold, sale, turbo kit, turbocharger
