Old 05-22-2014, 01:29 PM   #1
kdoubt
My Ride: 330i
Question My shifts are @ different intervals than others, do I have a differential swap/upgrd?
Ran out of room in the title. I assure you I can spell.
Anyway, I've been looking up other peoples 0-60 in car videos for the helluvit and noticed I have to change to 3rd before I hit 60, or 100 as I'm in Canada.
Here is my vehicle information: http://www.bmwarchive.org/vin/km05621.pdf
Just curious about what exactly differentiates what I'm driving every day to what I'm seeing in some videos.
Here is a video of 0-100km in my car (Skip to 1:30) :
Thanks for the help all
kdoubt is offline   Reply With Quote
Old 05-22-2014, 02:05 PM   #2
Alex323Ci
My Ride: M3 & 323Ci (sold)
bmw speedo is optomistic, so not the best way to determine exact speed. even harder to do when jumping on it because it's moving so much.
either lift the rear of your car and rotate the wheel one exact full revolution and count the exact number of times drive shaft turns and any increments like .25, .10 etc while doing this. if you do just a little under three (for example) you probably have a 2.93
or you could cruise for a while at 60mph and see what your rpm says. then go to the Diff Calculator site and input your car's info (like tire size/wheel size/5 speed, etc and see what it says you should be at for which ratio diff.
Old 05-22-2014, 03:20 PM   #3
Kubica
My Ride: 2003 325xi
Use a GPS to determine rpms at a given speed. Enter data and tire specs into a gearing calculator.
Old 05-22-2014, 03:22 PM   #4
Andy2108
My Ride: SpecE46 & E46 M3
yeah do this.
autos have a 3.46 manuals have a 2.93 IIRC
De gustibus non est disputandum.
Old 05-23-2014, 09:54 AM   #5
kdoubt
My Ride: 330i
This could be difficult, I've got different sized tires on my rears than I do on my fronts. Winters are ready to come off, just havent purchased good summers yet.
Would there be something labeled somewhere if I jack it up?
Old 05-23-2014, 11:28 AM   #6
Alex323Ci
input the rear tire size
yes a white label with numbers on the diff, but it's at the top of diff
you're making this a lot harder than needs to be.
Old 05-23-2014, 11:34 AM   #7
Alex323Ci
go cruise 65mph in 5th gear for like a mile and tell me your rpm, and rear tire size. we'll plug the number in for you in you need
Old 05-23-2014, 12:02 PM   #8
TerraPhantm
My Ride: M3 & ZHP
Since the speedos are optimistic, that would mean the reading would be even higher than expected.
Instead, his reading is much lower. So either someone really screwed with the speedometer scaling, or he has a diff upgrade. Depending on how much it's over reading, it looks like it could be a 3.64 or even a 3.91
Old 05-23-2014, 02:54 PM   #9
Weste46
My Ride: 2001 330ci
Wouldn't his larger diameter tire throw off the speedo reading as well?
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 05-23-2014, 03:43 PM   #10
Alex323Ci
yep, make the calculation of speed read lower on his speedo
0-100, 0-60, acceleration, differential
