Old 05-29-2014, 10:56 AM   #1
cptnbeard
My Ride: e46 328i, e30, 318ti
GM5 failed and Clutch slipping after swap
Hello!
I just recently replaced the motor and clutch on my 99 328i, and i have came into a few problems once i got it running. the 2 biggest being that my GM5 module has failed and the doors wont unlock. But the most important one im trying to figure out is the clutch. Its and F1 Racing Stage 2 clutch with LUK flywheel. The dam thing slips, mostly in 3-5th gear. and the pedal disengages the clutch at about 5% down. so i feel as if the clutch isnt full engaging and im not sure why. any help would be greatly appreciated.
cptnbeard is offline   Reply With Quote
Old 05-29-2014, 12:19 PM   #2
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
Was your F1 clutch a sprung hub? Because LUK flywheels are dual mass (there are springs inside the flywheel). You may have mis-matched parts and need the matching flywheel. Post a link to the exact clutch you bought.
Cavi Mike is offline   Reply With Quote
Old 05-29-2014, 05:02 PM   #3
cptnbeard
http://forum.e46fanatics.com/showthread.php?t=899434
This is the clutch I used
Old 05-29-2014, 06:09 PM   #4
Cavi Mike
Banned User
My Ride: 2000 328Ci
Yeah, that's a sprung-hub disc, you can't use that with the LUK dual mass flywheel. You have a miss-match of parts right now. Transmission has to come back off - you need a different flywheel. Get the F1 chromoly flywheel.
Old 05-29-2014, 07:21 PM   #5
cptnbeard
http://pages.ebay.com/motors/link/?n...856828&alt=web
So this should work fine then?
Old 05-29-2014, 08:45 PM   #6
Cavi Mike
Banned User
My Ride: 2000 328Ci
If you already have the clutch and pressure plate, all you need is the flywheel - though I'm not seeing it sold separately. Might want to try contacting them and let them know your situation. XTR, F1, FX - they're all the same company.
Old 05-30-2014, 05:44 PM   #7
cptnbeard
So what'll be easier, pulling the motor and dropping the trans, or drop the driveshaft, tilt the motor back, and drop the trans? My biggest problem with that would be getting the starter back in. I had trouble with that while the motor was out.
Old 05-30-2014, 06:37 PM   #8
cptnbeard
pages.ebay.com/motors/link/?nav=item.view&id=161265681420&alt=web
This is the clutch kit currently installed^^
http://www.ebay.com/itm/161265681386
And this is what I will be replacing it with.
Old 05-30-2014, 09:34 PM   #9
typeflex
My Ride: e46
F'n shiet! I have a 99 328i and I'm already dreading the day I have to get the clutch changed out. Good thread so that I know what to purchase when it comes time.
typeflex is offline   Reply With Quote
Old 05-31-2014, 10:48 PM   #10
cptnbeard
In all honesty, I think I'll just pull the engine again to get to the clutch.. Or I'll take it to a shop.
Unless someone else knows a trick to get the starter back on and the lining around the trans? I don't have access to a lift either. This will be done on jack stands..
Old 06-01-2014, 12:35 PM   #11
Cavi Mike
Banned User
My Ride: 2000 328Ci
I haven't done a clutch yet on the E46 chassis so I don't know what's different since the E36 but I did my E36 on jackstands as well by dropping the trans out the bottom. So far all I've heard that's different with the E46 is the cabin air intake needs to be removed.
clutch, gm5, locks, slipping, swap
