Old 06-23-2014, 08:53 AM   #1
jsdp
My Ride: 2001 E46 330ci
Necessesary to change alternator + fuel filter with fuel pump?
I just changed the fuel pump out of my 2001 330ci after it died on me and was wondering if i needed to change the alternator and fuel filter with it?
Could the fuel pump potentially die with the old alternator?
I have plans to change the fuel filter in the next few weeks however I don't have much time at the moment so I have been delaying it.
jsdp is offline   Reply With Quote
Old 06-23-2014, 09:16 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Change the fuel filter soon, it needs to be done anyway.
As for the fuel pump failing, it is time and it was just worn out, nothing to do with the alternator.
But if the car has the original alternator is may be time to change it or at least the brushes and Voltage regulator.
Old 06-23-2014, 09:31 AM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
My Alt failed at around 250K miles. But, you should do your belts and pulleys if you haven't done them. Monitor your voltage when running using the cluster display. It will probably be low and at that point, I think it's just as easy to put in a remanned alt...and not have to worry about the alt's bearings going bad. Fuel filter is a good thing to do every four years or so...some probably do it sooner...but I've heard of them being so clogged at 130K miles that they stop the car.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 06-23-2014, 10:33 AM   #4
jsdp
Ill be sure to do that soon, is it an easy diy? Thanks !
Old 06-23-2014, 10:45 AM   #5
orb
orb's Avatar
My Ride: 325Ci
Fuel filter is hard the first time, because everything is kind of seized if it's original. Be sure to get new clamps and new hose, 30R9 spec. I used 30R6 not knowing it couldn't handle the pressure and sure enough had a leak in about 1000 miles. Redid it in 30 minutes with the right stuff.
orb is online now   Reply With Quote
Old 06-23-2014, 11:40 AM   #6
Bino5150
My Ride: 99 323i
I had a severe misfire on 3 cylinders when I got my car, due to a clogged up fuel filter.
Bino5150 is offline   Reply With Quote
Old 06-24-2014, 08:39 AM   #7
markusmarkus
My Ride: 2001 330Ci
The first step for working on your alternator is to determine which alternator is in your car! Why? BMW sources 3 (!) different alternators for the E46:
- Bosch 80 amp
- Bosch 120 amp
- Valeo 80 amp
Remove the air filter housing and using a flashlight and a mirror read the label on the rear side of the alternator.
The VR in either Bosch alternator is replaceable. I got mine from FCPEURO for less than $40. Installation took about 30 minutes. The VR in the Valeo is NOT replaceable. You can't replace a Valeo with a Bosch unless you're swap the connector at the rear of the alternator. Also, the pulleys are different.
Old 06-24-2014, 08:44 AM   #8
jfoj
- Bosch 80 amp
- Bosch 120 amp
- Valeo 80 amp
Need to add Valeo 120 Amp alternator to your list as well!! I just replaced one a few weeks ago and have the old one in my garage still.
FYI, if you need a Valeo, ECS had good pricing on brand new Valeo alternators and they drop ship quickly. This does not help the OP as he is not in the US, but may help others that run across this thread.
I was able to get mine the next day with standard shipping as the alternator was drop shipped from the same state I live in.
Old 06-24-2014, 02:25 PM   #9
3c
OO[][]OO
My Ride: E46 E53 R129W202W124
Originally Posted by jsdp View Post
I just changed the fuel pump out of my 2001 330ci ...
how many miles ?
did you check the fuel pump relay to ......
Alternator [$150] = Bosch #AL0703X
3C
E46 CLUB [SF Bay Area CA USA]
http://autos.groups.yahoo.com/group/BMWE46club/
US
'01 330-2Ci Sport [Silver/Black] 5sp MT 150k miles
'01 330Ci Sport [Silver/Gray] 5sp MT 8k orig. miles
'05 X5 4.4i Sport 70k miles
'99 Benz SL50R AMGsport 50k miles
'96 Benz C280 Elegance 16k orig. miles
'89 Benz 300TE Wagon 160k miles
EU
'93 Benz 250TE RWD Wagon Diesel 5sp MT 200k km's
3c is offline   Reply With Quote
alternator, diy, fuel filter, fuel pump, need to change
