Old 07-23-2014, 06:43 AM   #21
NumbaOneNewb
My Ride: 2003 330CI Silver
try disconnecting your maf sensor and run the car
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 07-23-2014, 07:10 AM   #22
jfoj
My Ride: 330CiC, M5, X5, E93
Newb do you even read or do you just have ADHD? If you would have read the thread, I think you will see the problem has been identified and is not a problem with the car.
Also disconnecting the MAF is not really a solution or test for most no start situations.
Old 07-23-2014, 04:33 PM   #23
MattRivNCSU
My Ride: 2004 325i
So, this morning I had it towed to the shop and my mechanic pumped out roughly a 50/50 gas to water solution. Unbelievable. The gas station is going to pay for the repairs so all should be well.
I appreciate the help guys.
MattRivNCSU is offline   Reply With Quote
Old 07-23-2014, 04:48 PM   #24
jfoj
Make sure the shop CLEARLY documents what happened and what they found.
Key piece of info, fuel tank was full when towed in AND how much cocktail had to be pumped out of the tank.
Have the fuel filter replaced and bill that to the gas station along with the rest of the work.
They have insurance for things like this anyway.
Old 07-23-2014, 10:00 PM   #25
NumbaOneNewb
Yeah my bad. I did read it half ass. Never will I go answer questions after having not fully woken up. Apologies
Old 07-24-2014, 02:00 PM   #26
tsiu6
My Ride: '99 323i
Glad to see it got solved. Scheisty ga$$ station.
tsiu6 is offline   Reply With Quote
boot, ccv, misfire, vacuum leak
