E46 Convertible
Old 08-07-2014, 03:29 PM   #21
taylor192
My Ride: 2003.5 M3
Originally Posted by Three28iguy View Post
AFAIK? acroynym for...?
As far as I know AFAIK is as far as I know.
LMGTFY
Old 08-08-2014, 03:01 AM   #22
Skiddkid
My Ride: BMW E46 330ci
Just ordered my kit it should be here tomorrow! Can't wait I'll post pictures of before and afters
Skiddkid is offline   Reply With Quote
Old 08-08-2014, 01:44 PM   #23
RelaxIN
My Ride: BMW 330Ci
Originally Posted by CarbonZHP View Post
Need a little help on this topic, I'm slightly color blinded... I just installed a set of Orion AE 6000... and now people are telling me that my factory headlights and driving lights are a different color. If I had to replace my factory headlight & driving light bulbs to match the 6000 AE's what would you recommend...? the car is a 2001 330 with factory lights.. any thoughts...??
RelaxIN is offline   Reply With Quote
Old 08-11-2014, 09:17 PM   #24
Skiddkid
Are you looking to go back Factory? And I'm posting pictures of the lights I just got them today and they look amazing! Went with 8000
Old 08-12-2014, 02:28 PM   #25
RelaxIN
My Ride: BMW 330Ci
No... what I'm saying is... The car still has all of the factory lights with the exception of the AE's that I recently installed which are Orion 6000... I like the color of the AE's so I want to change my factory bulb's to match the AE's... does that make sense...?
Old 08-13-2014, 11:02 AM   #26
johnrando
My Ride: '06 330 CIC ZHP
So just buy osram or phillips bulbs at 6000K and you're set.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 08-13-2014, 11:43 AM   #27
RelaxIN
My Ride: BMW 330Ci
Okay... I wasn't sure if the 6000k Phillips bulbs would be the same shade or temperature color as the AE.. I know sometimes the colors vary per manufactures...
Old 09-17-2014, 07:37 AM   #28
pppham
My Ride: 740il S500 330CiC
I am not sure if this is the right place to post. Anyway, I installed the AE on my 330 CIC for couple years now. Took the vert in for service due to the roof top recently. Got the car back and now my AE is not working. Ordered a new set, replaced both AE and the hardness, wired exactly as I did before (wired into accessories wire - red/white with yellow stripes) and the darn thing still not working. Is it possible for the shop to turn off this function?
Thanks,
pppham is offline   Reply With Quote
Old 09-17-2014, 10:32 AM   #29
taylor192
My Ride: 2003.5 M3
Thanks,
Hard wire it to 12V to check if they light up, if they do then your wiring is bad somewhere.
There should be no way to disable the "accessory on" wire in the compartment under the hood...
Old 09-17-2014, 11:08 AM   #30
pppham
I will try to hard wire it today. It just bugged the crap out of me why both were bad. With eng. is on, I have tested the accessory wire and got 14v in the fuse box in front of driver side. I have checked the +wires from AE go to +pos on the front of passenger side and got 14v. You mentioned wiring is bad somewhere - are you talking about the AE hardness?
Old 09-17-2014, 12:18 PM   #31
taylor192
My Ride: 2003.5 M3
The AE only hooks up to ground, 12V, and accessory on (and remote trigger if you use the dimming feature).
If you hookup accessory on to 12V and it still doesn't work, then something is wrong with the AE harness. I think the AE harness has a fuse, did you check that?
Old 09-17-2014, 12:26 PM   #32
pppham
Yes, fuse is good.
Old 09-18-2014, 07:24 AM   #33
pppham
Got home from work yesterday, hard wires the old one to the battery - no light (as I suspected). hard wires the new one - and there is no light (oh crap!) Now what? Further inspection of all wires, I noticed the wire that connected to our car accessories cable had a kink about 50mm from the end. Tested for continuity and got nothing. I decided to cut couple mm behind the kink, stripped, connected to the battery - and there is light.
Taylor192, you are correct. It was a bad *&^&ing wire (the one that connect to accessory cable). I can not believe DOA for a new product. L&L, never assume, test the product prior to the installation. It should be a 30 mins job, turn out to be two days for me.
Anyway, thanks to all for the advices.
P3
led, lighting, lighting upgrade
