Old 08-17-2014, 11:32 PM   #1
oddis
My Ride: E28, E30s & E34iX
S54 Turbo vanos setup. 1060 WHP/1130Nm & 1167 WHP/1300Nm
A couple of friends of mine have been pushing the S54 turbo setup for quite a while now. They have togheter with the help of PPF in Sweden been thinkering with the dual vanos setup witch is a big gamechanger in producing mid range V8-ish torque witch improves driveability and power delivery insanely. (Needs to be boost controlled through the rev range to save the gearbox)and increases driveability and makes it possible to fit a much lager turbo and get a longer and higher power curve with no sacrifice on spool up time
To give you an example. A PT7675 on a non-vanos S54 can do 1000whp. With vanos it can only do 850whp because of the difference in exhaust back pressure generation. That is sick!
This week one of them (driving a E30 2 door with a fully buildt S54B32 with BW380 80mm turbo and 1060whp (2.2bar) / 1130Nm(@6300rpm) (833 lbs?) and E85 fuel) took the car to a track day festival and let it rip.
(Fully build S54 with forged pistons, rods, ARP bottom and top, L19s in top, Athena cooperring PPF headgasket, titan retaniers and heavy duty spring, stock cams, active vanos, MaxEcu EMS, homemade intake and exhaust manifold, BW380 80mm, 60mm wastegate, tilton clutch and E85 fuel are the rough spec)
Another friend of mine, with a E21 (The former YouTube 1000whp silver one): also has a fully build S54B32, this time with Precision 8284 (82mm) turbo. He also uses E85 fuel. He went to PPF and dynoed in their Dynpack until the figures on the screen was 1167WHP / 1300 Nm torque (6500 rpm / 2.2 bar) - and then followed by a big red ERROR message from the bench. It couldn't hack it any more! They had to reduce torque in mid range also.
So they pegged it down to a Dynapack friendly 1111 WHP & 1100Nm ;D
Both cars are mapped by PPF in Sweden witch have been developing these S54 dual vanos setups for some years now, and use MaxxEcu's from Sweden and have a preloaded program witch enables them to set up the engine very qucikly and cheap. Setting up dual vanos cams in the ECU could take days of testing, and many tuners don't even manage to set them up even remotely correct.
Lets hope it's just the start for S54 vanos application in boosted engines. Purpose made cams and some more clever work with the vanos could make it even better (?). Lets hope so..
And by the way. These engines have stock cylinder liners.
The 1167 whp E21 build by JAAS Performance in Norway:
oddis is offline   Reply With Quote
Old 08-17-2014, 11:43 PM   #2
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
It's about time u guys got the word out about the power u r making .... Awesome.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 08-18-2014, 12:28 AM   #3
Brevik
My Ride: Tiag M3
Crazy video. How many tires per gallon are you getting?
Brevik is offline   Reply With Quote
Old 08-18-2014, 09:24 AM   #4
BDUB328I
My Ride: bmw 328i S54 sedan (
haha wow! those cars look awesome! I love the shaved bay with s54 and giant turbo! looks amazing
Share more info! don't hide all your projects until your done.
BDUB328I is offline   Reply With Quote
Old 08-18-2014, 10:20 AM   #5
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
Great video! Simply Awesome.
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 08-18-2014, 10:24 AM   #6
djtrini
My Ride: 04 M3 & 05 330i ZHP
That is badass!!!
djtrini is offline   Reply With Quote
Old 08-18-2014, 04:24 PM   #7
oddis
Here is some more. Including some propper burnouts at the end, with and without straight pipes.
At 4:40 the real good stuff
Old 08-19-2014, 03:56 AM   #8
E85head
My Ride: E46 M3
Obviously VANOS affects when the exhaust (and intake) valves are open, but how does this increase in ebp?
E85head is offline   Reply With Quote
Old 08-19-2014, 05:13 AM   #9
Davew
My Ride: 2004 330ci Msport
Would have it at a guess that sacrificing boost during overlap, and accounting for it in the air fuel ratio would equate to cooler running, more power potential.
Davew is offline   Reply With Quote
Old 08-19-2014, 05:13 AM   #10
Davew
Fantastic vehicles
Old 08-19-2014, 09:00 AM   #11
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Incredible!!!
Viral@ActiveAutowerke is offline   Reply With Quote
Old 08-19-2014, 10:28 AM   #12
Jørnen-a
My Ride: E21 s54 turbo
The purple one is my car:-) me and my buddy anders skei (we are jaas performance) also build the turbo kitt on the grey e30:-)
Jørnen-a is offline   Reply With Quote
Old 08-19-2014, 11:14 AM   #13
bmech211
My Ride: '06 Carbon Black M3
WOW, that's one hell of a flat torque curve. Are you guys running stock 260/260 duration cams? What are your thoughts on some of the staggered set-ups, 280/272 in particular, on a boosted S54?
I'm not looking to run anything close to what you guys are putting down, but I'd like to try and squeeze a nice flat 500rwtq on stock DME with an EFR 9180. Also in the slow process of fabricating a P54 (replica) dual plenum intake for much improved air distribution.
Not looking for you to post any of your trade secrets, if that's the case, but definitely would like to pick your brain further.
"Do or do not, there is no try"
bmech211 is offline   Reply With Quote
Old 08-19-2014, 11:15 AM   #14
nek0
My Ride: e85 turbo m3
what kinda compression ratio are you guys running for these setups??
nek0 is offline   Reply With Quote
Old 08-19-2014, 11:24 AM   #15
Jørnen-a
We use stock cams. We havent tried any other cams yet. And i really dont se any reason to go for any other camshaft yet. We have sick power band whit the stock cams and vanos. Even with the precision 8284 gt47 turbo its strong from the bottom. And the powerband is still staigth upp on 8000rpm:-)
Old 08-19-2014, 11:24 AM   #16
Jørnen-a
The comp on our engines are 8,7.
Old 08-19-2014, 11:40 AM   #17
bmech211
Thanks for the reply Jørnen-a. Great work BTW.
Old 08-19-2014, 11:50 AM   #18
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
O M G !!!!
I'd prefer in the E46 M3 Platform or even the E92 M3 tho
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline   Reply With Quote
Old 08-19-2014, 02:23 PM   #19
BartenderPlease
My Ride: '03 540i/6 M-Sport
This is just brutal.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 08-19-2014, 06:45 PM   #20
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Badass...gotta pick an E30 up!
1060whp, e30 turbo, s54 turbo, vanos
