S54 Turbo vanos setup. 1060 WHP/1130Nm & 1167 WHP/1300Nm - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-20-2014, 09:17 AM   #21
bmech211
My Ride: '06 Carbon Black M3
Hey Jørnen-a, curious to know if you guys kept a log of what your LSA's (lobe separation angle) were when tuning?
"Do or do not, there is no try"
bmech211 is offline   Reply With Quote
Old 08-23-2014, 06:58 PM   #22
bimmerguy055
My Ride: M3
Send a message via AIM to bimmerguy055
to the OP, do you have pictures of the exhaust manifold? is the motor less slanted then normal? curious to know how you routed the oil drain. Do you have a heat issue (from turbo/downpipe)
Without Failure There is No Success
bimmerguy055 is offline   Reply With Quote
Old 08-25-2014, 07:51 PM   #23
Orange fever
My Ride: M3E90/M3E46/
interesting.....sick numbers
M3 E46 VFE Stg.3/ M3 E90 SC VF620 ///
EAS /// Radenergie /// STM /// VF-Engineering /// Vorsteiner ///
Maintenance/Modings/Detail : SouthBay Autohaus /// Candccollision /// Promobileautodetail
March issue of Eurotuner :
http://forum.e46fanatics.com/showthread.php?t=651379
Orange fever is offline   Reply With Quote
Old 08-27-2014, 04:50 AM   #24
oddis
My Ride: E28, E30s & E34iX
The S54 in the E30 is tilted up more than stock yes.
AN 10 hose is normal to use on turbo drain. Some even drill and tap the drain straight into the timing chain cover, especially on M50s.
Exhaust manifold:
Turbo drain into E34 M50 pan.
oddis is offline   Reply With Quote
Old 08-27-2014, 05:45 AM   #25
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Exhaust manifold:
Absolutely beautiful.
What size are those primaries?
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 08-27-2014, 10:25 AM   #26
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Next up: S85
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 08-29-2014, 03:53 PM   #27
oddis
Originally Posted by CarbonZHP View Post
Next up: S85
Yes, that has to be the next step. PPF have already delivered their first setup to a customer in Iceland if I'm not mistaking. I think it's the same guys who had the E39 M5 TwinTurbo and E30 M3 "RingToy" S50B32 euro at the Nurburgring.
Vidar Strand at VS Motor (the guy with the 9 second 1000hp E34 M5 youtube screamer and E36 M3 S38 1422hp drag race car) buildt a sleeved destroked 4.8L S85 back in 2010 ish. And dynoed 1851hp and uses it for dragracing. Google it and you'll find the video.
The setup from PPF:
Oil feed size is AN4 usually. Note that ball bearing usually has a little different flanges sometimes becuase they require less oil volume. I see COMP turbos have 1/4" NTP on 360 bearings and 1/8" on ball bearings inner size.
Old 08-29-2014, 06:33 PM   #28
BDUB328I
My Ride: bmw 328i S54 sedan (
Wow awesome, I can't imagine what that thing is like to drive
BDUB328I is offline   Reply With Quote
Old 08-31-2014, 12:41 PM   #29
Jørnen-a
My Ride: E21 s54 turbo
The ppf build s85 are moundet in a swedish e46 drift car:-)
Jørnen-a is offline   Reply With Quote
Old 09-29-2014, 03:05 PM   #30
oddis
Oh dear... another dyno session at PPF after fitting bigger injectors +55 WHP at same boost (2.2 bar).
Ended up popping a shim and bending a valve. According to PPF the turbo could do 1150WHP.
Old 09-30-2014, 02:38 PM   #31
Twin_Turbo_S54
My Ride: M3
S54 pop shims after certain power figures been there by 2009.
A custom made valve train is the key.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 10-01-2014, 01:23 PM   #32
Jørnen-a
You dont need a full custom valvatrain. Supertech valvesprings is the only thing you need. In my first s54 turbo engine i used standard springs. It poped shims sometimes. But only wen it backfired It pop shims if you run the revlimiter whit only ignition cut and it goes bang. It phushes the valve down due to the high presure you get when it backfire. And then the shim pops out. This also hapens when if there somtingh wrong and it backfire. The e30 in the tread have som trigger problems and backfire because of that. I run 1111 whp and never poped a shim. M3micke runs 1260whp and has never poped a shim. No backfire=no shim poping.
Old 10-01-2014, 04:14 PM   #33
KCPBMW
My Ride: 325Xi W/Rob43 Susp.
OP, a work of art. Nice job.
KCPBMW is offline   Reply With Quote
Old 10-05-2014, 02:18 AM   #34
Soorena
My Ride: S1000RR
Bluethunder's E30 S85 will be NA and probably coupled to DCT.
Soorena is offline   Reply With Quote
Old 10-06-2014, 03:05 PM   #35
Twin_Turbo_S54
My Ride: M3
No backfire, yes shim popping.
Hitting rev limiter
A boost cut based ignition cut
A traction control based ignition cut
these all trigger shim popping...
Old 10-07-2014, 12:38 PM   #36
Jørnen-a
No. Then you are doing somthing wrong.:-) we have solved the problem whit just supertech springs and god tuning. We have dynoed our cars and can prove our power.;-)
Old 10-07-2014, 12:56 PM   #37
Twin_Turbo_S54
My Ride: M3
Since when is hitting rev limiter wrong
Since when is traction control based ignition cut wrong
Good to see your power
Old 10-08-2014, 06:11 AM   #38
Littleturbo
My Ride: Car
Dont make a fool of yourself like Always,and dont try to be smarter then these guys because you never will be that smart.
They always show a dyno and not like you with a 1200Whp banner without proof.
Littleturbo is offline   Reply With Quote
Old 05-31-2016, 09:45 PM   #39
oddis
Time for a update. Last year 1115whp @ 2 bar boost with Borg Warner 8082 turbo. This year swapped down to a Precision gen 2 6870 turbo. 12mm downsizing compressor. That came to 949whp @ 1.8 bar.
Makes it easier doing this Sounds like a machinegun sometimes without muffler
Old 06-08-2016, 11:30 AM   #40
zander271
My Ride: 6spd ZHP/5sp XI
Wow great builds. Anyone who drives that e30 face must hurt from the big ass grin they would have ok their face.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
1060whp, e30 turbo, s54 turbo, vanos
