Old 10-03-2014, 04:08 PM   #1
AndreBXP
My Ride: 2001 BMW 330ci
OEM Xenon Retrofit onto a car that used to have Xenons
Alright this a an odd situation; So after I bought my car I went and looked up with BMW VIN decoder what the car had from the factory. Well, The car was equipped with Xenons from the factory, but the PO seems to have replaced them with halogens. Now my question(s): Can I buy any Pre-Facelift OEM Xenon headlights used from somewhere(ie. CL, eBay) and just plug them in? Will my car have to coded, and can I do it with PA Soft? Also what has to be included with the headlight to make this work? My car is a 2001 330ci. Thanks in advance!
AndreBXP is offline   Reply With Quote
Old 10-03-2014, 05:15 PM   #2
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Im unsure if youll need to recode, but if you do its easy with PA Soft. Just programmed someones who bought oem xenon retrofits
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 10-03-2014, 05:46 PM   #3
AndreBXP
Alright good to know, Does anyone know if the sedan and coupe headlights are interchangeable? If they aren't, can I just swap the contents from the Xenons into my existing headlights? Thanks
Old 10-03-2014, 05:49 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
They are not interchangeable due to the corner light (coupe is curved, sedan is straight/slanted). The internals can be swapped from what I can see but don't quote me on that.
Old 10-03-2014, 10:22 PM   #5
AndreBXP
So after poking around on eBay some of these projector headlights go for $100-200. The headlight housings are in rough shape, but the internals are what matter. I would swap the Xenon components(Projector, ballast, ignitor) into my halogen headlight housing, then plug it in, and it should work(right?). As for the headlights I would use 6k bulbs but I'm unsure where to buy D2S bulbs. Any help would be awesome.
Old 01-30-2015, 10:49 PM   #6
cxoakes
My Ride: 2002 330ci vert
I am in the exact same situation.(previous owner put halogens in) Any updates on how your experience went?
cxoakes is offline   Reply With Quote
xenon
