Old 10-12-2014, 03:58 PM   #1
davidlopez69
My Ride: 2001 330i
Exclamation Rough idling and misfire!
Hi guys, Im new to E46 fanatics and to the BMW world.
Alright so I've had my 2001 BMW 330i over a year now currently at 155k
My car was fine 2 days ago and recently my car has had a very rough idle and misfire on all 6 cylinders. Now i have researched on here and found very similar forums but have not fixed my problem yet so if anyone could direct me to the right thread or tell me what to do.
Just replaced:
-spark plugs
-ignition coils
-O2 sensors
So I just replaced these and computer says Im still misfiring on all 6 cylinders and have a rough idle... and even it turned off once... I have already checked for leaks in the intake boots and nothing i have also done the MAF test to see if it preformed worse but no so I know its not the MAF sensor. My next guess would be fuel injectors or fuel pump or filter but is there anyway one can know for sure before I do anything else super expensive
Thanks!
davidlopez69 is offline   Reply With Quote
Old 10-12-2014, 06:55 PM   #2
lszlszx
My Ride: 1.8T, XC70
What type of code reader do you have?
Scan for codes, if there are codes set, post freeze frame data.
That is needed to help you diagnose it.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 10-12-2014, 08:17 PM   #3
markusmarkus
My Ride: 2001 330Ci
You've missed likely have a vacuum leak. I bet you'll read a P0174 code. Very common issue. It could also be a cam position sensor but I'm getting a vacuum leak is the culprit.
Old 10-12-2014, 08:18 PM   #4
markusmarkus
My Ride: 2001 330Ci
"...missed...." should be "....most..."!
Old 10-12-2014, 08:51 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
Problem is not going to be fuel injectors or coils.
Vacuum leak or fuel pump are the most likely causes.
Codes, Freeze Frame and Fuel Trim data would be useful.
In the short term, read the first 2 links below in my signature.
Old 10-12-2014, 09:03 PM   #6
mbogosia
My Ride: 2001 330i
In regards to the fuel pump if you don't know when it was last replaced or it has never been replaced you might as well do it anyways before it fails and leaves you stranded.
mbogosia is offline   Reply With Quote
Old 10-13-2014, 08:18 AM   #7
markusmarkus
My Ride: 2001 330Ci
And replace the following when you replace the fuel pump:
- fuel filter
- fuel hoses and clamps at fuel filter
- vacuum hose from fuel filter to intake
Old 10-13-2014, 02:36 PM   #8
davidlopez69
My Ride: 2001 330i
Alright thanks a lot for the feed back guys im going to my mechanic right now to check for the vacuum leak once again and also to replace fuel filter and pump
Old 10-13-2014, 02:37 PM   #9
davidlopez69
My Ride: 2001 330i
I will be back to post what the culprit was
Old 10-14-2014, 01:37 AM   #10
davidlopez69
My Ride: 2001 330i
aright so I found the problem! It was a vacuum leak like markusmarkus said along with my DISA. replaced both and my car is running better than before along with fuel filter and pump thanks a lot guys!
Old 10-14-2014, 05:25 AM   #11
jfoj
Just to prepare you for all the vacuum leaks your engine may have, check the 1st link below in my signature. Brake booster failures are becoming common around year 12 on these cars as well. Been seeing more and more of these lately.
330i, idle, misfire, rough idle
