Old 10-29-2014, 11:12 PM   #1
Novaskotia
My Ride: 2001 330cic
Question Downgrade 330ci to 2.5L?????
I have a blown m54b30 in my 330ci Vert. I found a M54b25 to buy. Can i just swap it in there?
I have searched far and wide for a thread like this, didn't find anything..
Everyone wants to go from 2.5L to 3.0L , but i never saw anything about going the opposite direction.
Any thoughts?
Novaskotia is offline   Reply With Quote
Old 10-29-2014, 11:44 PM   #2
raptorman5174
My Ride: 330i ZHP
No way man, be patient I'm sure you can find a used m54b30 out there, SEARCH. No reason to go backward, and the swap would be plug and play if you go with the correct motor.
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 10-29-2014, 11:59 PM   #3
JapanRot325ci
My Ride: 04 E46
loool no.
just go back to a 3.0l or a s54 swap
you're gonna regret it big time if u go to a 2.5l...lesss power harder to swap because youll need to hard code etc
JapanRot325ci is offline   Reply With Quote
Old 10-30-2014, 12:03 AM   #4
HakenTT
My Ride: 323i with S54
Yes you can. I actually did that. Customer wanted better gas mileage after his 3L blew up. He ordered complete 2.5L from same year, I did the swap. It all fits and bolts right up, then you will need to flash your engine computer for the 2.5L engine.
HakenTT is offline   Reply With Quote
Old 10-30-2014, 06:03 AM   #5
Gus330vrum
My Ride: 330ci
:Facepalm: very dumb move.. Who moves backwards?!
Gus330vrum is offline   Reply With Quote
Old 10-30-2014, 08:23 AM   #6
rsyed07
My Ride: E92 335is, E46 330i
The 3.0 actually gets better gas mileage than the 2.5 .
rsyed07 is offline   Reply With Quote
Old 10-30-2014, 08:23 AM   #7
Grande D
My Ride: E36 M3
Yes you can, but don't. You will trash the resale value of the car, and the convertibles are too heavy for you to give them any more of a speed handicap.
It will change your life!
Old 10-30-2014, 09:28 AM   #8
TRITONAL
My Ride: 04 330Ci
Definitely not with my experience, and I own both. The 2.5L easily yields 2-3 more mpg (calculated).
Originally Posted by wildirish317 View Post
The E46s are the Knights of the chessboard. They can outmaneuver the other, more powerful pieces on the board. They aren't the King or Queen of the garage, but they are the first piece that you want to move.
TRITONAL is offline   Reply With Quote
Old 10-30-2014, 09:37 AM   #9
My Ride: Lexus
EPA rates both engines the exact same as far as economy. My experience owning both is my 330i got slightly better economy than my 325ci by 1-2mpg (while both totally stock and both 5-speed manuals).
Old 10-30-2014, 10:01 AM   #10
TRITONAL
My Ride: 04 330Ci
I'm running both automatics, though the 325i has 100k more miles. I think I'll need to run a little Seafoam through mine to clean out the mess from the PO.
But OP, most people go the other way. I would hold out for one (if you can), or search for one outside of the area you are searching. Don't give up so easily!
Old 10-30-2014, 11:52 AM   #11
Novaskotia
Thanks for all your reply's
(fangirling about Mango responding)
I have took what most of you said into consideration. I think I will wait it out now. I was considering throwing that 2.5 in there and just selling it right away, as a 3.0 - but that is dishonest. I will keep you posted.
Old 10-30-2014, 04:07 PM   #12
JoMoCo
My Ride: 2003 325it
More likely the differences in mpg may be related to differential gearing ..
http://www.bokchoys.com/differential/GearRatios.htm
JoMoCo is offline   Reply With Quote
downgrade, engine, m54b25, m54b30, swap
