DISA Valve - Genuine vs. Aftermarket - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 02-27-2015, 11:04 AM   #21
fordinews
My Ride: 2002 330 Ci
Hi everyone! My name is Fernando and I live in Montevideo, Uruguay.
I drive a 2002 330 Ci and apparently my DISA valve died.
I've been reading here and I really don't know what to do since I may have here the Vaico DISA for something like $ 250 vs the BMW original part for $ 660! due to import taxes on parts over $ 200.
What would you do?
Thanks a lot for your time!!!
fordinews is offline   Reply With Quote
Old 02-27-2015, 11:56 AM   #22
Astheros
My Ride: BMW
What would you do?
maybe you can get the disa repair kit from german auto solutions. they also sell a complete disa replacement that is stronger than the original.
Evil men will triumph so long as good men stand by and do nothing.
Astheros is online now   Reply With Quote
Old 02-27-2015, 12:11 PM   #23
fordinews
Thank you very much but since I was in a hurry cause it's friday anda had to have the item sent to you Uruguay I just bought the Vaico Valve from ECStuning. I let you know how it works.
Congrats for your car... it's a beauty!!
Old 02-27-2015, 10:00 PM   #24
323i jlviii
My Ride: 323i, 2 330xi, X3
I put in a "rebuild kit" one, ebay had it for like $23.00. compared it to what I took out, the new one has the metal "push" pin for the end. Thought of putting a drop of lock-tight on it, but didn't. Checked it the other day when I was replace the CCV and it still operates fine; and that metal push pin, still in there tight.
Doesn't mean I don't wonder why there's not key-way, locking something on it.
323i jlviii is offline   Reply With Quote
Old 01-16-2017, 10:23 AM   #25
pic27
My Ride: BMW 2002 325i
If anyone is looking for just the DISA O-Ring, here is one that definitely works : www.ebay.com/itm/162117908513
pic27 is offline   Reply With Quote
Old 01-16-2017, 10:51 AM   #26
lingon300k
My Ride: 2005 325xi Automatic
German Auto Solutions
That's where most people buy their DISA parts. It's a reputable company. eBay is eBay.
lingon300k is offline   Reply With Quote
Old 01-16-2017, 11:50 AM   #27
jfoj
My Ride: 330CiC, M5, X5, E93
So are you the ebay seller of this item??
This item appears to be WRONG, too thick, based on the picture. Most of the ebay sellers offer O-rings that are TOO THICK for the 325/330.
As mentioned that O-ring pictured is too thick, it will work for the 323/328 but not the 325/330.
The 325/330 O-ring is 3/32", the O-ring you are showing is 1/8" thick.
You cannot believe everything you see advertised on ebay, MANY, MANY of the O-rings sold on ebay are not the correct O-rings.
So please do us a favor and do not post this all over the Internet, if you are going to provide information, make sure it is correct and accurate.
Old 01-16-2017, 03:26 PM   #28
jfoj
So again I have to do everyone's job!!!
I contacted the ebay seller that was listed above and asked a very simple question:
"Can you advise how thick this O-ring is?"
This was his reply:
"I don t have a micrometer with me to confirm exactly. I have been buying these to match the OEM specifications of 11617504543 rather than by size. Once I found the one that works for my own 2002 E46, I have been ordering in bulk."
Well the BMW Part Number 11617504543 is the 1/8" replacement O-ring for the 323/328 (2.3l and 2.8l) engines. These O-rings are too thick and should not be used on the 325/330 (2.5l and 3.0l).
SO, we have a seller that is clearly providing the wrong part for the application!!
Old 01-22-2017, 06:49 AM   #29
pic27
Guys, I suspect we are seeing commercial interests getting in the way of free information sharing here. The eBay listing that jfoj is badmouthing is CLEARLY the correct o Ring.
www.ebay.com/itm/162117908513. The proof is in the pudding. It says 530 sold with 100% feedback. Go check it out for yourself. With that kind of record, This does not sound like the wrong product to me. The reason I know is because it was the one that I used. Have no concern, it works. it just disrupts the business of people who want to charge $17, $18, $19 for this thing. Worse yet, trying to sell a whole new DISA claiming that just because this is not designated as a BMW serviceable part, it means it cannot be fixed. It can.
Old 01-22-2017, 07:08 AM   #30
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
Yes very common issue the season for the usual car runs rough on start up, misfires, CEL/MIL, stalling. Before you get too deep into this thread, I believe most of the data is relevant to the 325/330 models, or typical the 2.5L M52tu and 3.0L M54 engines also used in the E39 5 series and E85??Z4 series (however, it may be relevant to the 323/328 models as well, but part numbers will probably vary?), please check part number and application carefully before placing parts orders.
Eurobahn BMW MINI Mercedes Benz Audi of Greensboro is your local independent BMW Greensboro We offer BMW service at the dealer-level Service & expertise at a fraction of the cost at our BMW Greensboro dealership.
Eurobahn BMW is offline   Reply With Quote
Old 01-23-2017, 07:26 AM   #31
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
rebuild it
http://www.germanautosolutions.com/d...sa_kit_diy.php
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
after market, disa valve, genuine bmw parts, intake, oem
