Old 11-18-2014, 12:12 PM   #1
kozmo
My Ride: 03 325i Sedan
Question 2000 323i Transmission Swap GM for ZF....is it possible?
I have a 2000 323i with the infamous "no reverse".....can the BMW GM transmission be swapped for the ZF transmission? GM Transmission came out of a 2000 323i.
kozmo is offline   Reply With Quote
Old 11-18-2014, 12:20 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
No, I believe they use different computers and wire harnesses. Would be very inconvenient to say the least. A manual trans swap is your best option at this point
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 11-18-2014, 03:24 PM   #3
glhx
My Ride: 2002 330ci
Forget that. Just get an updated reverse drum and install it. You just need hand tools and a clean workplace.
All the information you need on the 5hp19 is in my sig below.
The amount of information on rebuilding the ZF is so good that I would not even recommend getting a used transmission. It would cost you less to rebuild the ZF and have a brand new upgraded one. I'd replace the torque converter as well with one that has an updated viton seal instead of the rubber one.
You could have it out in 3 hours. Jjrichars videos are excellent. All is linked in that thread below. Good luck.
glhx is offline   Reply With Quote
Old 11-18-2014, 07:29 PM   #4
kozmo
I hear you.....and I'm very handy, doing probably 75-80% of the work on my engine....but I've never even attempted a transmission, not sure I could do that, and I don't have a lift. But it has crossed my mind!
Old 11-18-2014, 07:59 PM   #5
HakenTT
My Ride: 323i with S54
To replace the drum whole transmission needs to be apart. It is very time consuming and most likely transmission will fail soon after.
HakenTT is offline   Reply With Quote
Old 11-18-2014, 07:59 PM   #6
WDE46
IDK why a lift matters with a swap vs a rebuild...
gm, swap, transmission, zf
