Old 11-27-2014, 10:43 AM   #1
ghyelde
My Ride: 2006 M3
Misfires
2005 ZHP. went through all the hoses in the intake system per a post on this forum. found the leak that was causing major lack of power, etc. started car and while it ran better it was still rough. found one cylinder with a misfire. moved the coil to a couple of different cylinders and the misfire moved with the coil. replaced the coil - yes everything I read says replace all but this does not make sense to me - and while the car runs 90% better, there is still a misfire in a single cylinder. move the offending coil around and the misfire follows it.
am I just unlucky and have a weak coil that shows up sometime, or are the electrics tied together somehow?
thought are appreciated, glenn
ghyelde is offline   Reply With Quote
Old 11-28-2014, 08:23 AM   #2
markusmarkus
My Ride: 2001 330Ci
Have the codes read. That's always the first step.
Old 11-28-2014, 09:18 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
You provide no solid data, how do you know the problem is moving with the coil?
You may have multiple problems cause different misfires.
Need OBDII info - Freeze Frame, Fuel Trims @ warm idle and steady cruise.
Codes in PXXXX format.
EXPLAIN when the misfires occur, in detail.
Everything is outlined in the first 2 links below in my signature.
Old 04-18-2015, 10:29 PM   #4
aleksankazakov
My Ride: 04 E46 330i sport
Send a message via ICQ to aleksankazakov
I had soimething as well, I think this is a good tip:
aleksankazakov is offline   Reply With Quote
misfire
