Old 01-10-2015, 06:12 PM   #1
josh.sellers130
My Ride: 2001 330ci
Thumbs down 01 330ci rough idle, no start... unusual suspect? help!
My 01 330ci started to idle rough a few weeks ago paired with a constant red battery light. Ok, no problem I said. Voltage of battery at 12.7 and tested good. Voltage running is 13.8 and alternator tested good. Starter is fine, all my connections are fine, no blown fuses anywhere.
This left me at a loss. I went so far as to replace crank and cam sensors which also did nothing. Charged battery. Nothing. Decided to reset computer. Nothing.
As time goes on the problem worsens. Idle becomes more rough. All coils test fine, replace spark plugs and still come up short. The traction control light comes on shortly after. Then I have no power to the heating and cooling system. Then the radio stops working.
So this morning I went to start it. The only features that powered on were features that work when the key is in position 1. So I start to push it into the garage as it won't start (no power to fuel pump, it cranks but no start.)
Here's the kicker. I had the key in position 2 to push it and out of the blue the cluster illuminates and the pump primes. Hell yes! I start it up and make it 5 feet until all of this cuts out again and I start to push. Now it's got a mind of its own choosing when it wants to power the cluster and pump.
I'm at my wits end. What do we think here guys? Dme malfunction? Ignition switch?
josh.sellers130 is offline   Reply With Quote
Old 01-10-2015, 06:24 PM   #2
djacs1
My Ride: 2001 325i
Replaced the battery lately? These guys are real goofy when the battery starts to degrade. lots of weird indications. keep reading and searching here for battery issues.
djacs1 is offline   Reply With Quote
Old 01-10-2015, 06:26 PM   #3
josh.sellers130
My Ride: 2001 330ci
The battery is under a year old. I even went as far as the run it with a buddies battery with the same result.
Old 01-10-2015, 07:09 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Check the engine to body ground. On the North American cars it is under the car near the right side motor mount, usually the frame side goes bad.
Old 01-10-2015, 07:17 PM   #5
josh.sellers130
My Ride: 2001 330ci
That's been checked and cleaned. Good to go.
asc light, battery light, no power, no start
