Old 01-21-2015, 11:25 AM   #1
ElliottUT
My Ride: 330xi
Very intermittent cold start problems
I have a 2001 330XI automatic with about 160K miles on it. It is my wife's daily driver. About every 2 months we will have a cold start issues. It either idles really rough with the roughness disappearing after 30-60 seconds warming up OR it won't idle at all and I just crank and crank with the gas pressed down until it finally catches and then idles rough until it warms up. In both cases the exhaust smells like hell. The car throws no CEL.
Here's what I was thinking and tell me where I'm wrong:
1) Original VANOS, but probably not this because no CEL? Though bad valve placement due to bad seals might create my situation (rough until warm and seals start to seal)...
2) CCV: I'm sure they're cracked somewhere, but I would assume a leak would not create this as intermittent as it appears only every 2 months or so...
3) DISA: primary culprit? Would it throw a CEL? Would it be this intermittent?
4) ICV: if it was bad I would think it would not be so intermittent.
I've read all the other threads on this similar issue, but hoping mine is more unique due to the intermittent issue AND that I will sometimes get a rough idle or a no-start that self corrects after warm-up.
ElliottUT is offline   Reply With Quote
Old 01-21-2015, 11:56 AM   #2
Tament
My Ride: 2001 330I
Do a quick cleaning of your ICV and see where you come out. There are DIYs on here for it.
Tament is offline   Reply With Quote
Old 01-21-2015, 11:58 AM   #3
YOnpds
My Ride: E46
Has the fuel pump and or the fuel filter been replaced. If so, at what mileage?
YOnpds is offline   Reply With Quote
Old 01-21-2015, 12:37 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
14-15 year old car, it needs a lot of things replaced.
VANOS would be the last item on the list.
Read the first 2 links below in my signature.
Read my "BMW 20 Questions" comments in this thread - http://forum.e46fanatics.com/showthread.php?t=1059972
Old 01-21-2015, 06:50 PM   #5
ElliottUT
My Ride: 330xi
The fuel pump/filter has never been replaced to my knowledge. I never thought that would be an issue (thinking they are either bad or they aren't). Great writeups by the way. Thanks.
Old 01-22-2015, 12:45 AM   #6
YOnpds
My Ride: E46
I had similar starting problems and then the pump failed completely. Either way, you still need to replace both. You are way overdue. Good luck!
ccv, cold start, disa, rough idle, vanos
