Old 01-30-2015, 01:12 PM   #1
Colby.d17
My Ride: 2004 BMW M3
2003 M3 passenger mirror moves when i move my seat
Okay i am having a pretty interesting problem. My passenger side mirror moves all the way up or to the right when i adjust my seat, now i have memory seats and i have all my Mirror's and seat positions set but when i went to switch my seat position my Passenger side mirror moves. Even if i correct it and set the mirror back where it should be, it still moves out when i switch my seat position. Any help would be appreciated.
Colby.d17 is offline   Reply With Quote
Old 01-30-2015, 09:45 PM   #2
lmr2wil
My Ride: '00 328Ci
When you say you correct it, do you mean that you place the mirror where it should be along with your desired seat position and then re-save these settings into your seat memory slot? If not, that's what I would try first. If so, do you have access to PA Soft or the like? There is some communication with the seat memory / mirror module available - it may be of help?
Luke
lmr2wil is offline   Reply With Quote
Old 01-30-2015, 10:29 PM   #3
redfeathers
My Ride: 2001 bmw 330 ci
Lots of us have the same problem, only mine moves down when I shift to reverse.
Solution......Move the switch to one side OR the other and see if that stops it. Then leave the switch in THAT position. It fixed mine.
2001 bmw 330 ci 250k miles white AUTO A5S 325Z steptronic
redfeathers is offline   Reply With Quote
Old 01-30-2015, 10:40 PM   #4
lmr2wil
My Ride: '00 328Ci
Of course this is a feature not a bug... for aiding in parallel parking and (hopefully) not curbing your wheels.
Old 01-30-2015, 10:55 PM   #5
Colby.d17
I re-save the seat position after i put it back. And I should note that it happens with all 3 seat positions even if I have the mirror locked or in the position they allows be mirror to go down when reversing.
Old 01-30-2015, 10:56 PM   #6
Colby.d17
I'm not sure what those programs are...
Old 01-30-2015, 11:17 PM   #7
invisible man
My Ride: invisible car
invisible man is offline   Reply With Quote
Old 01-30-2015, 11:21 PM   #8
fastsoup
My Ride: 05 M3 Vert/11 X3 M
Originally Posted by invisible man View Post
lol
fastsoup is offline   Reply With Quote
Old 01-30-2015, 11:44 PM   #9
Colby.d17
The mirror moving down in reverse is a feature not a problem. You can shut this feature off but this isn't the problem I am having.
Old 02-06-2015, 04:50 PM   #10
Colby.d17
Bump
Old 02-06-2015, 04:53 PM   #11
pshep138
My Ride: 2005 BMW M3
pshep138 is offline   Reply With Quote
Old 02-06-2015, 06:34 PM   #12
mleindek
My Ride: 2009 X5
LOL we should file a claim to BMW about this issue.
mleindek is offline   Reply With Quote
Old 02-06-2015, 07:04 PM   #13
choxor
My Ride: JDM
GM5 issue?
mirror, seat
