e46 Electrical Problems - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-07-2015, 02:09 PM   #21
Thate46Life
My Ride: 2000 BMW 323ci
Sorry jfoj, it's my first car relatively. And I'm constantly learning. As for yesterday I could not get the belt off. I'll be trying to get it off today and go from there.
Thate46Life is offline   Reply With Quote
Old 02-07-2015, 03:59 PM   #22
jfoj
My Ride: 330CiC, M5, X5, E93
Why are you removing the alternator if you do not now it is bad, get the battery charged up and you can test the alternator on the car.
Old 02-09-2015, 01:28 AM   #23
Thate46Life
Like I said earlier, I did, I jump started the car, unhooked the battery and it died shortly after. Hence the alternator was not giving enough charge. I took the alternator off yesterday, got it tested, and it was only charging 11v. I then picked up my new one and put it on this morning and now its charging again. Problem solved, thanks to all the people that helped me out.
Sponsored Links
Advertisement
Old 02-09-2015, 02:04 AM   #24
TerryH
My Ride: '99 328i
Good to hear you got it sorted out.
TerryH is offline   Reply With Quote
Old 02-09-2015, 02:08 AM   #25
Thate46Life
Yup the old 323 is up and running again. Now I just have to replace brake pads, ebrake and lines. Then comes wheels, tires and coilovers.
Old 02-09-2015, 02:20 AM   #26
invisible man
My Ride: invisible car
Nope. That means you blew up a perfectly good alternator. Can't unhook the battery like that with the car running.
Giubo. G I U bo. Pronounced joo-boh. Don't allow yourself to sound ignorant.
invisible man is offline   Reply With Quote
Old 02-09-2015, 02:43 AM   #27
TerryH
My Ride: '99 328i
He was jump starting the car. He removed the jumper cables and the car died before he could get the meter across his battery to read the alternator output voltage.
Old 02-09-2015, 06:16 AM   #28
jfoj
In the future, DO NOT disconnect the battery cable when the engine is running on these or newer cars. This test went out in the 70's and you were lucky there was not damage done to modules and electronics in the car.
Buy yourself a cheap Voltmeter, you NEED one for for your tool box along with then OBDII smart phone App and interface for $30 or less.
alternator, dd, dim lights, no power, no start
