Old 02-07-2015, 02:34 PM   #1
Mbojo911
My Ride: 2000 328ci
Can my E46 drive with sheared vanos bolts?
I just did my vanos seals and sheared the two reverse-thread torx bolts holding the unit onto the housing. Since there are many other bolts holding it on as well, should i be able to drive around with half of the threaded part still in? I tried to get them out but I couldn't and I have work on monday so I need my car
Mbojo911 is offline   Reply With Quote
Old 02-07-2015, 02:37 PM   #2
Gatriel
My Ride: IS 250
These are low torque bolts -- try backing them out with a pick. Its what I did when I ripped the head off the intake side last month.
Gatriel is offline   Reply With Quote
Old 02-07-2015, 02:57 PM   #3
cvx5832
My Ride: 325Ci, 325Cic, C300
Those two reverse threaded bolts don't hold the VANOS to the head, the connect the VANOS pistons to the cam. No, I don't recommend starting that car at all.
I'm on the road and can't view your profile, but if you happen to be near 94598 you're in luck I have two pairs of those bolts laying around.
cvx5832 is offline   Reply With Quote
Old 02-07-2015, 02:59 PM   #4
Gatriel
My Ride: IS 250
He is Ohio, so yeah.
Old 02-07-2015, 05:18 PM   #5
Mbojo911
My Ride: 2000 328ci
Nevermind! THANK YOU SO MUCH! The hook and pick set worked! called a specialized BMW mechanic before I bought the set and he charged me $500+ to take out those sheared bolts next week and I would've had to tow my car over. Thanks!
reverse thread, sheared bolt, torx, vanos
