///M3 Forum
Old 02-16-2015, 02:47 PM   #1
ironicinori
My Ride: 2006 M3
Is the "Valve Adjustment" in Inspection 2 the same as VANOS
Hello, I am getting Inspection 2 done on my 2006 M3 at 60,000 miles. Included is a "valve adjustment". I have also heard that when the miles start to rack up, the VANOS seals WILL corrode and go bad eventually.
Does anyone know if the work they do in Inspection II is correcting the VANOS decay? Or should I have the mechanic install new vanos seals from Besiansystems or something as well.
ironicinori is offline   Reply With Quote
Old 02-16-2015, 10:19 PM   #2
Kansas Corey
My Ride: Upcoming: E46 M3
They are different. Within Inspection II there is no vanos work. In fact, I don't think it's "officially" within any of the maintenance checklists regardless of mileage.
Valve adjustments (part of Inspection II) are the intake and exhaust valves on the head. Vanos unit controls cam shaft timing (both exhaust and intake camshafts on E46 M3) and is bolted to the front of the engine.
Kansas Corey is offline   Reply With Quote
Old 02-17-2015, 06:29 PM   #3
Iceyankee-TSI
My Ride: 2003 BMW M3
You are correct Kansas Corey. There is no Vanos work included in Inspection 2. The hot topics on S54 engines right now other than valve gap adjustment are the following:
1. Vanos oil pump tabs verification (susceptible to break at any mileage)
2. Intake Camshaft sprocket bolts failure(shearing off)
3. Upper right timing chain tensioner failure(tip of tensioner breaks)
4. Vanos solenoid o-rings leak (o-rings between the vanos unit and it's solenoid deteriorate)
I can't think of anything else.
Iceyankee-TSI is offline   Reply With Quote
Old 02-22-2015, 12:50 PM   #4
dafoe
My Ride: LSB M3
Hey! Just like the others have said, there's no vanos work in Inspection II. I'd ask your mechanic though to verify, and take pics, of the two exhaust camshaft driver tabs. One you'll have verification if they are broke, and two you'll know they opened up the engine to do the valve adjustment.
If the tabs are in tact proceed at some point with all the Beisan fixes. Or get an already rebuilt vanos from Dr. Vanos. His units have updated seals, and smaller oil pump disk holes that will remedy the broken tab issue.
2001 M3, LSB 6spd, purchased 6/09 with 25K miles.
Mods: Coyne Performance built ///M3
dafoe is offline   Reply With Quote
inspection 2, m3, valve adjustment, vanos
