Old 02-25-2015, 05:38 PM   #1
Colby.d17
My Ride: 2004 BMW M3
E46 M3 fog light issue
So I went to go and change my fog lights and I noticed that the previous owner and installed xenon bulbs in there and the bulbs I ordered are for the stock set up. I am wondering if anyone knows how to change it back to the stock set up and if so what do i need?
all help is appreciated!
Colby.d17 is offline   Reply With Quote
Old 02-25-2015, 05:49 PM   #2
My Ride: Lexus
pull junk out, replace w/ stock bulbs. Did he modify them in some way?
or you can do what I did and install LED units from a 2014 BMW X5. Can search if curious.
Old 02-25-2015, 06:10 PM   #3
Colby.d17
the adapter isn't the same to install the factory bulb. The xenon bulb has 2 wires attached from it and that goes to 2 other connectors. Can i get a factory adapter?
PS: I can post pictures if needed
Old 02-25-2015, 09:38 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
The factory harness is connected to the ballast. Then the ballast is connected to the hid bulb. Just pull out the bulbs and the ballast, put in the halogen bulb into the fog light and the factory harness goes into the bulb.
Old 02-25-2015, 11:24 PM   #5
Colby.d17
Perfect! Thanks man
Old 02-26-2015, 11:13 AM   #6
My Ride: Lexus
Originally Posted by Colby.d17 View Post
Perfect! Thanks man
yeah. like i said. pull out junk and put stock bulbs...
Old 02-26-2015, 12:47 PM   #7
Colby.d17
I wasn't disagreeing, the answer was just vague
9006 fog lights, fog lights, wiring, xenon, xenon bulb
