Old 03-31-2015, 02:48 PM   #1
Dubz1
My Ride: e46
lowering
Hi anyone got any info on how the e36 springs perform on the e46 ? Ive seen a couple of people have tryed and fit but no one has said how thay perform
Dubz1 is offline   Reply With Quote
Old 03-31-2015, 03:07 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Can't you buy the correct set of E46 lowering springs (new or used) for your Bimmer ?
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 03-31-2015, 03:20 PM   #3
Dubz1
My Ride: e46
Rob43
Hi mate ive jus bought and fitted 40mm all round but wanted 60mm on front. As far as im aware thay are near on the same but dno how thay handle my pal has some 60mm e36 springs laying about. I cant find 60mm for e46 only e36 without goin coilovers and dont want any cheap coilovers
e46, lower, springs
