Old 04-03-2015, 12:39 AM   #1
KnockKnockVanos
My Ride: E46 330i
Exclamation M54B30 Swap in to a 325i?
Now in most circumstances I'd just buy a 330i. However my 325i has a cracked block and I don't have the money to buy a whole new BMW, so I found a guy who's giving me a smoking good deal on a 330i M54B30. He's selling the whole car for 1500. The car was written off buy insurance after some one had broken in and vandalized the interior. Mechanically she's sound with only 78,000KM's on the clock. I just need a "Yes" or "No" answer if I can swap the new motor in with the exisiting DME, EWS, Keys, etc. Any tips would be great.
KnockKnockVanos is offline   Reply With Quote
Old 04-03-2015, 12:43 AM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Yes.
Since you have a Complete working donor Bimmer, this should be fairly easy.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 04-03-2015, 01:21 AM   #3
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
i don't understand how you can use a 325 DME on a 330. isn't the DME the "ECU"?
Old 04-03-2015, 12:36 PM   #4
TerraPhantm
My Ride: M3 & ZHP
The DMEs are the same, the software is different. Just flash the 325 DME with the 330 software
You can use the donor DME, EWS, keys, etc. but I wouldn't. Keep your existing electronics so that you can always order new keys without issues and so that you don't run into issues when it comes time for inspection (some states don't like it if the VIN in the software doesn't match the car's VIN)
Old 04-03-2015, 02:21 PM   #5
R.vans
My Ride: b30 swapped 325ci
If you aren't technologically inclined, it'd probably be much easier for you to swap the keys/cluster/barrels/DME/EWS and call it a day.
However, reflashing your current DME with the tune for the b30 is a much more elegant solution, and not hard at all once you get WinKFP up and running on a computer.
If you want to know more about this, head over to the DME Tuning subforum and search through some posts about WinKFP there. The gist is that you need to use the ZUSB of a DME from a 330 car and tell WinKFP to flash that info to YOUR DME.
R.vans is offline   Reply With Quote
Old 04-03-2015, 03:02 PM   #6
Phrygian
My Ride: 2000 323i
I don't think that the software is even different. When I flashed my MS42 to EU2 the ZUSB code was the same for both the 323 and 328. Maybe that's just for EU2 though.
Phrygian is offline   Reply With Quote
Old 04-03-2015, 03:36 PM   #7
TerraPhantm
My Ride: M3 & ZHP
Shouldn't be the same. RealOEM may have had a mistake.
For the 325 and 330 they can't be the same. They use different injectors and MAFs -- things won't be scaled right.
Old 04-03-2015, 03:42 PM   #8
Phrygian
My Ride: 2000 323i
Of course, there's really no difference between a M52TU25 and M52TU28 except the stroke.
Old 04-03-2015, 04:09 PM   #9
peytonracer4
:D
My Ride: '00 328i
Should the fuel injection be different then? And the timing?
Old 04-03-2015, 04:21 PM   #10
TerraPhantm
My Ride: M3 & ZHP
The tune pretty much has to be different for the DME to figure out how much fuel to inject. The MAF can account for some of the difference, but the DME also has to know how much fuel to inject in the event of a MAF failure.
It's much more likely that there's an error in the realoem database. There are a few of them all over the place
Old 04-03-2015, 06:28 PM   #11
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
TP is correct. The DME firmware is different for the same year 325 and 330. I did this exact swap with my 2004 325Ci last year. I just had to locate and flash in the correct MS45.1 DME firmware, reset adaptations, and it worked fine. You need WinKFP for flash updating.
Make sure you get the entire intake from the donor 330, since the air box, MAF, boots, spacer, and throttle body are all larger on the 330. All the other engine peripherals are the same.
///Mmmmmm...
Old 04-03-2015, 06:34 PM   #12
BaliDawg
That might be the case on the M52TU motors, but not on the M54's. The 330 motor has some different internals. For example, the crankshaft is forged. More details here.
http://www.e46fanatics.com/faq/m54engine.html
///Mmmmmm...
Old 04-04-2015, 06:59 PM   #13
Phrygian
My Ride: 2000 323i
Both M52TU versions use the same fuel injectors and MAF. Unlike the 330/325, the 323/328 use the same intake manifold. As far as I know, the heads are exactly the same also.
There plenty of people have flashed the same ZUSB that I used on thier 328, and they haven't had issues, nor have I. The US ZUSB codes are however different for the 323 and 328.
Old 04-04-2015, 07:43 PM   #14
TerraPhantm
My Ride: M3 & ZHP
RealOEM has a database error
7528722 is correct for the 328
7538736 is correct for the 323
Just because the fuel injectors, maf, and intake are the same does not mean the software is the same. Those items being the same just allow the car to run reasonably well, especially at less than full load.
Old 04-05-2015, 02:53 PM   #15
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Easy swap, change out your motor with tranny at the same time. Need the hood all the way up and tilt you motor/tranny to get it.
Change out all maintenance items like CCV, WP, THERMOSTAT, WATER PIPES, HOSES, VCG, ENGINE MOUNTS, OPG and OFHG.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-05-2015, 03:59 PM   #16
Phrygian
My Ride: 2000 323i
So, how did you figure this out? Were you using another site/database? I can see now that there are more part numbers than there should be for the 323i. Also, I noticed that the 323Ci vert doesn't list the wrong part numbers.
What's really crazy is that my car drives fine. In fact it runs better than it did before the flash. I guess I'm going to have to get out the laptop and try the other ZUSB to see what it does.
Old 04-16-2015, 05:47 PM   #17
KnockKnockVanos
My Ride: E46 330i
Update: I had a whole donor BMW 330ci, the car was written off due vandalism, thankfully all the components I needed were fine. I ended up swapping the locks keys, ews etc. I was more work than I bargained for, but I couldn't source a local M54B25 motor. It ended up taking 2 days of prepping the cars & 3 days to reassemble. Now I plan on rebuilding the M54B25 with a low PSI turbo & stroker kit. I'll post some photos a friend of mine took of the swap as soon as I see him. Any questions about the swap feel free to ask!
m54b25, swap
