Old 04-18-2015, 08:35 PM   #1
Ldub
My Ride: 2002 325i
Cool Assist Diagnosing Temperature Sensor Issue
Hi There,
Advance apologies if I'm posting in an incorrect area and thanks for any assistance.
We have a 2002 BMW 325i with 98,000 miles. A good well loved car. A few months ago I happened to catch that the temperature was in the red hot. I was at a light, no where to pull over. As soon as it turned green I went to pull over but by that time (maybe 1 minute), it was back at the normal halfway point.
Recently this has started happening frequently and driving my crazy since at first I was pulling over every single time, until again I was stuck at a light and saw it do the quick return to normal.
It shows no signs of actually overheating- and will go from red to normal abnormally fast. It will only happen once while driving. Once it's done it's craziness it will stay at the normal halfway point and the coolant light will come on. The coolant light is NEVER on when it's in doing it's moving into the red and out.
The coolant level is right where it should be. The only code is an 02 sensor - unrelated? Reading other posts I understand this is likely a temperature sensor issue... and there are multiple sensors?
Sorry for the untechnical language- I'm not the mechanic in the family. Just the member who gets the ball rolling by posting to find out the plan and pass it along.
Thank you in advance.
Best,
Ldub
Ldub is offline   Reply With Quote
Old 04-18-2015, 08:47 PM   #2
Nicker
My Ride: 323ci
Its possible there is a problem with your fan or the module which controls it.
It seems that once you come to a stop, there's no air flowing through the radiator, so everything will heat up.
Once you start driving, things cool down again.
I would check those first then move on.
00' 323ci - 170hp
Nicker is offline   Reply With Quote
Old 04-18-2015, 08:57 PM   #3
Ldub
My Ride: 2002 325i
Wow, thank you for the quick reply.
Sorry I should have specified. It's not isolated to happening when stopped. I've tried to time it to see if there is a common time for it to happen... about 7 -12 minutes into driving- it can happen on the highway... stop and go..
Old 04-19-2015, 08:21 AM   #4
markusmarkus
My Ride: 2001 330Ci
Has the car's cooling system been "overhauled"? The cooling system on these cars is made of plastic. The heat cycles and age cause the plastic to get brittle. The consensus here and on other E46 forums is that the system needs to be overhauled at or close to the 100k mile mark.
I bet your cooking system has s major problem at this point. Replacing or repairing an overheated engine will cost you thousand ($2500 min). Either follow Mango's cooling system stickie, or find a good independent ("indy") shop to do it for you. Either way make sure ALL COOLING SYSTEM PARTS ARE EITHER BMW OR OEM! Don't scrimp by using cheap eBay or aftermarket parts. In the end those cheap parts will let you down. Btw, I've owned and worked on my BMWs for more than 40 years.
Old 04-19-2015, 09:09 AM   #5
My325XI
My Ride: 03 325XI Sprt Prem
Agree with Marcus for a total system overhaul. The issue to me sounds like the thermostat failing.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 04-19-2015, 12:29 PM   #6
Ldub
My Ride: 2002 325i
Thank you both. Within the past 2 years we've replaced the radiator, expansion tank, upper and lower hoses and I believe the thermostat.
From performance, and the unusually quick way the gage is moving I don't get the sense it is actually overheating- though since I can think of anything worse to do to my car besides maybe drive it into the ocean, I also don't want to take any chances that it actually is overheating. I've had computer issues in the past that affected the transmission, so once after it shot up into the red, I pulled over, turned it off and turned it back on a few minutes later and it was back to the middle. It will also only happen once in a driving session.
Would you recommend our first step maybe be replacing the thermostat? I will look for the Mango Cooling System Stickie.
Thank you again.
Old 04-19-2015, 12:42 PM   #7
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
It sounds like there may be air in the system. If the gauge moves quickly, might be because of an air pocket there. Bleed the system.
Also, check the coolant flow and maybe replace your water pump. More than once I have seen an impeller disintegrate leaving little pumping ability.
///Mmmmmm...
Old 04-19-2015, 01:33 PM   #8
BaliDawg
Originally Posted by My325XI View Post
Agree with Marcus...
C'mon, at least spell his name right. It's MarkusMarkus, so bad ass they named him twice.
///Mmmmmm...
Old 04-19-2015, 03:16 PM   #9
Ldub
My Ride: 2002 325i
Thank you.
We're going to start with bleeding the system and see where that gets us. Will report back- but probably not going to get to it until mid week- and won't be driving it until we give this a shot. Watched videos from E46Mango and WorldMechanic... Sounds promising and a solid DIY. All crossables crossed!
Old 04-19-2015, 05:37 PM   #10
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Start with the bleeding...and then therm sounds like the best guess, since it's responsible for maintaining the flow of coolant. While you're at it, though...make sure you don't have pulleys hanging up...that your belts are good...but I think it's probably either bleeding or therm...sounds like it's stuck closed...doesn't happen often, but it does...and get an OE therm. Off market ones don't play nice with our cars. I think Wahler is OE, but don't quote me.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 04-19-2015, 05:45 PM   #11
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Use the OBD hidden menu to view your water temperature and see how it is reacting when being driven.
It will give you a much better idea on what may be happening.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
coolant, inaccurate temperature, sensor
