Sponsored by BimmerWorld
Old 05-11-2015, 09:03 AM   #1
Bijouuu
My Ride: E46 m3
330ci Koni/h&r or Blisten/h&r
I have a 03 330ci with stock suspension
I want a aggressive drop but don't know which one to get
H&R sport or H&R race ? Please help me out.
Also which shocks are better with the H&R .. Koni or Blisten?
Bijouuu is offline   Reply With Quote
Old 05-11-2015, 01:24 PM   #2
Knight
My Ride: '05 330Ci | '01 325i
You can't go wrong with any combination of the struts/shocks/springs listed above.
That said, if you want the firmest/lowest setup of the bunch, go with:
-E46 Bilstein B8 or Koni Sport (Yellow) Struts
-E36 M3 Bilstein B8 or Koni Sport (Yellow) Shocks
-H&R Race Springs
Knight is offline   Reply With Quote
Old 05-11-2015, 02:24 PM   #3
Bijouuu
My Ride: E46 m3
-H&R Race Springs
Which H&R race # .. #29484 will give me the most aggressive drop, or am I wrong?
Old 05-11-2015, 03:24 PM   #4
Knight
H&R has some unclear numbers/naming conventions.
For an E46 without the factory sport suspension, the 29484's are considered the "Race" option.
For an E46 with the factory sport suspension, the 29484's are considered the "Sport" option.
For an E46 with the factory sport suspension, the 50484-8's are considered the "Race" option.
http://www.ecstuning.com/News/BMW_E4...rings/ES10800/
Old 05-11-2015, 08:19 PM   #5
zhenkaaaM3
My Ride: Fst'r then your e46
I had bilstein with h&r race springs on my e36 m3. It does give an aggressive drop in the front. The ride is bouncy as hell which led me to getting coilovers
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 05-11-2015, 11:19 PM   #6
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
^ The ride was bouncy because your dampers were not up to the task of controlling their aggressive spring rate. I personally run H&R Race springs, at first I had a slight bounce in certain conditions while on fresh E46 Bilstein Sports F&R. After a month or two I sold off my fresh E46 rear Billy Sports & bought E36 M3 Bilstein Sports,......problem completely solved under ALL conditions.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 05-12-2015, 06:27 PM   #7
zhenkaaaM3
Rob43
I had bilstein sports. Never liked the ride
Eugene
Old 05-12-2015, 09:02 PM   #8
nbesheer
My Ride: 2003 330Ci
I have an 03 330Ci and I just put on the Koni STR.T/H&R kit, it's much lower than it was and the ride is not that much worse, previously had stock sport springs with KYB (base model) dampers. I hit speed bumps even when going VERY slow, but I like the way it looks, and I will say that the car is much smoother than an E9X that I drove from BMW, likely because of the RFTs
nbesheer is offline   Reply With Quote
Old 05-12-2015, 09:22 PM   #9
evanr614
My Ride: 2000 328Ci
Very minimal bounce in some conditions with H&R race plus koni E36 M3 rears and E46 fronts. Set at medium for all shocks.
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
Old 05-12-2015, 09:29 PM   #10
Rob43
Rob43's Avatar
Once you've driven on them for that recommended 30 days & Fully understand how they react under certain conditions, then pull the rears & increase them a bit.
Then reassess.
Rob43
Old 05-14-2015, 11:32 AM   #11
seattle330
My Ride: '05 330i ZHP
I have the Bilstein Sport and H&R Sport (29484) combo, that's perfectly good for a DD application that you can also take canyon carving. On rough rides I get passengers complaining that it's bumpy.
seattle330 is offline   Reply With Quote
Old 05-14-2015, 01:33 PM   #12
bmwerkes
Para-Magic
My Ride: 01 330i, 5 spd
I think the konis are on sale for significantly less than the bilstein's.. That and the adjustability were my determining factors.
H&R Sways 27mm & 23mm
OEM Euro Clears
Dinan Strut Brace
bmwerkes is offline   Reply With Quote
330ci, e46, springs
