Old 06-25-2015, 12:36 PM   #1
Greengum
My Ride: 323i
Misfires and more misfires
I have a 2000 323i 4 door with 102,000 miles. Last week I got off the freeway and a couple lights down the road I stopped at a red. My rpm gauge went crazy and it stalled out. I cold start it but when I put it in gear it would stall out again. I had it towed home and now it won't start at all.
I rented a cheap code reader and it came back 0301,0303, 0304, 0305 cylinder misfire. I check the air Intakes and replaced some things. No improvement.
Any suggestions on where to start after ruling out the air intake parts?
Ty for your time.
Greengum is offline   Reply With Quote
Old 06-25-2015, 01:17 PM   #2
white46
My Ride: e46 323ci
What happened? You stopped at red light and RPM went crazy (guess hitting rev limiter) without you pressing on gas pedal? Is this 5spd or auto?
white46 is offline   Reply With Quote
Old 06-25-2015, 01:19 PM   #3
Handsomecore
My Ride: 2000 323i
Sounds like you have a vacuum leak .
Handsomecore is offline   Reply With Quote
Old 06-25-2015, 03:15 PM   #4
Greengum
My Ride: 323i
It an auto. I had my foot on the brake, the rpm gauge started jumping and when the light turned green I applied gas and then it stalled. When I tried to restart it, the engine was rough and it sounded like and felt like only running on 2 or 3 cylinders.
Old 06-25-2015, 04:32 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
Get an OBDII smart phone/tablet App and interface, typically $30 or less. These Apps are usually best for drivability issues and they support Emission Readiness Monitor Status, Freeze Frame and Live/Realtime data. They are also great for Logging data for review after the car has been driven and can really help find usual problems.
Android - Touch Scan for $3.95 and ELM327 OBDII to Bluetooth interface.
iProduct - OBD Fusion for $9.95 and ELM327 OBDII to Wifi interface.
I usually suggest getting the OBDII interfaces from Amazon if you are located in the US/North America. Make sure you choose an interface that indicates that the order will be "Fulfilled by Amazon" otherwise you may be waiting for WEEKS for an interface to arrive from Asia. Ebay is another option, but pay attention where the interface will be shipped from, again weeks for an interface from Asia, so if you can wait and want to try to save some money, go for it, but if you need an interface soon, choose wisely.
Read the 2 links below:
http://forum.e46fanatics.com/showthread.php?t=897616
http://forum.e46fanatics.com/showthread.php?t=929501
Need to see Freeze Frame info if the SES/CEL/MIL is on and Fuel Trim values at both warm idle and a steady highway cruise between 45-60 MPH.
P0102 means for some reason there is not likely a signal from the MAF. Verify if the MAF connector is properly plugged in, sometimes the female terminals in the connector are spread and loose on the MAF pins, sometimes there are broken wires inside the wiring harness between the MAF and the wiring box near the throttle body and sometimes the MAF just is bad with no output signal.
DO NOT buy a cheap ebay MAF, there are many Asian counterfeits on the market that do not work properly. See of there is an MAF reading in Grams/Sec. Most E46 have an idle MAF reading of between 3.5-4
Note, there may or may not be Lean Codes showing up. Lean Codes usually trigger at around 10% Fuel Trim values or higher. Keep in mind that sometimes these engines can have a Lean condition that does not or only intermittently triggers Lean Codes. This is why monitoring the Fuel Trims in real time is important. Ideal Fuel Trim values are typically in the 0% to +2.5/+3.0% range.
Read this thread - http://forum.e46fanatics.com/showthread.php?t=1057387
Make ABSOLUTELY sure the O2 sensor wiring has not been mixed up, read these links:
http://forum.e46fanatics.com/showpos...0&postcount=27
http://forum.e46fanatics.com/showpos...0&postcount=26
Read my "BMW 20 Questions" comments in this thread - http://forum.e46fanatics.com/showthread.php?t=1059972
Check for or be aware of cracked valve covers and bad valve cover gaskets:
http://forum.e46fanatics.com/showthread.php?t=1021219
http://forum.e46fanatics.com/showthr...e=2&highlight=
http://forum.e46fanatics.com/showthread.php?t=1053359
This information ASSUMES that spark plugs have been checked/replaced. If they have not been inspected, you also need to check for oil filled spark plug wells due to a leaking/cracked valve cover gasket.
http://forum.e46fanatics.com/showpos...2&postcount=11
Search YouTube for Scotty Smoke Test. Do what Scotty does or build a tester from related video. Remove the oil fill cap and make sure the crankcase fills up with smoke, put the oil fill cap back on and check for leaks around the valve cover, oil fill cap, dipstick tube and CCV hoses. Cracked valve covers are pretty common on the E46 as it ages.
Note that the Scotty Smoke Test method is not so good for smaller air/vacuum leaks or fully filling the engine crankcase, for this you really need a smoke machine that can provide a solid and continuous low pressure smoke stream. So plan on building a smoke tester of you thing you will use if more than once or may have smaller and harder to find leaks.
323i, diagnose, misfire, stall
