///M3 Forum
Old 08-21-2015, 12:55 AM   #1
GoodEnough
My Ride: '06 & '11 M3 ZCP
Springs Vs Coilovers (Daily Driver)
Hello, I was wondering your opinion on Springs vs Coilovers, I have read a couple of fourms on lowering springs for M3s, and non Ms and people were saying things about the front being higher than the rear? Im alittle confused about this, are all lowering springs like this? I was looking at H&Rs, seems to have the best reputation. Obviously springs cant give you the preformance as coils can, but I will be daily driving my car and I wanted a more easy solution considering I dont want to lower my car to the ground, or near it. I still want to be able to clear speed bumps, or go over them eaisly. (My schools parking lot and entrance is filled with them every 10 feet. Thank you.
2006 E46 M3 ZCP Jet Black/Black Fully Loaded, 2011 E90 M3 ZCP Jet Black/Black
GoodEnough is offline   Reply With Quote
Old 08-21-2015, 01:09 AM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
http://forum.e46fanatics.com/showthread.php?t=1082853
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 08-21-2015, 01:15 AM   #3
GoodEnough
Originally Posted by Rob43 View Post
Good price, but I dont know anything about spring rates, or what Im getting myself into. Whats a good spring rate for daily driving? Thanks.
Old 08-21-2015, 01:59 AM   #4
Rob43
Rob43's Avatar
If it were me, I'd pick the 380F & 500R as my DD. I'd also take the 445F & 600R as my aggressive driver / track springs.
E46 Suspensions like a Front to Rear spring rate ratio of roughly 25% to 50% more in the rear. Using this formula, multiply the front spring rate times about 33% & see what you get. Plus those "Special" Ground Control Koni's can easily handle either of those spring rates with NO problem. The other thing you don't currently realize is that Both the F&R dampers are Externally Adjustable, meaning it only takes seconds to adjust any of the four dampers. Being able to adjust all four dampers within seconds is worth its weight in gold.
Rob43
Old 08-21-2015, 11:48 AM   #5
CrowsFeast
My Ride: 330CI ZHP
Rob43
I was going to suggest the 380 and 500 rates as well, and externally adjustable is KEY! I had Koni Yellows on my old car, the fronts were external, the rears had to be removed from the car, fully compressed, rotated, then reinstalled (so I set them once I never touched it again).
I used to put the fronts to full soft after going out for all you can eat sushi
CrowsFeast is offline   Reply With Quote
Old 08-22-2015, 02:20 PM   #6
GoodEnough
So if I wanted to lower the car does the whole shock body turn or do i have to compress the spring?
Old 08-22-2015, 02:32 PM   #7
Rob43
Rob43's Avatar
Neither.
You insert a spanner wrench to lower or raise the circled adjusters. The springs are sitting on top of these adjusters & move up & down with them.
Rob43
Old 08-23-2015, 03:59 PM   #8
campygoob
My Ride: 2005 M3 Comp
Spring Rates
I agree with Rob43. A stagger between the front and rear will work best. My M3 came from the OP with 500/500 Koni based T C Kline SA. It was great on the street with the dampers turned from middle to all the way down. At the track, I would turn up the dampers and carry the inside front wheel on VIR Turn One. I switched to 500/600 and that solved that issue. Given that I drive hard on the track, I've moved to Nitron R3s with loose you teeth spring rates.
Good coilovers can be set up for excellent ride quality.
Fred
campygoob is offline   Reply With Quote
Old 08-29-2015, 03:38 AM   #9
Alex323Ci
My Ride: M3 & 323Ci (sold)
just get some H&R springs.
the drop will be subtle and the springs "progressive rate". also H&R usually have more an even stance while Eibach often more of a "raked" stance, with the nose down.
coil-overs often have components/hardware that isn't isolated. this can cause clunks with the springs when they shift. coil-overs aren't for everyone. since prices are so low nowadays it's often a mistake made to buy when a stock design spring/damper is best suited for street use.
Old 08-31-2015, 02:48 PM   #10
m3dragon
My Ride: CSL M3
Send a message via AIM to m3dragon
Alex323Ci has it right. Just get H&R and koni and done. Better ride than stock and also more performance. Simple is better for DD. Ran the setup as well and loved it
NorCal drive organizer guy
Drive database and photo locations
NorCal CSL build thread - US to CSL Conversion
E46 M3 GTR Street Car - Build Journal
m3dragon is offline   Reply With Quote
Old 09-15-2015, 01:33 AM   #11
M3revspeed
My Ride: TiAg DINAN-S2 M3
I'm currently running stock Sachs suspension with the eibach pro kit springs until my KW's come in, and it's not too bad. From what I've read the eibach pro kit is best for stock suspension. Click image for larger version
IG: M3revspeed
M3revspeed is offline   Reply With Quote
Old 09-16-2015, 04:58 AM   #12
braaang
My Ride: E46 M3
eibach prokit and koni yellows is probably the best basic upgrade suspension for a daily, but can also be hustled along quickly.
i've moved onto coilovers with 8kg front and 11kg rears and its a big improvement in performance, but ride quality does suffer. imo, not necessary for only a daily.
braaang is offline   Reply With Quote
Old 09-18-2015, 10:47 PM   #13
m3e46freak
My Ride: m Twee lol
To be fair... all coilovers do is provide a strengthen ride and ability to go higher or lower. Springs to me seem cheap and provide nothing but a bunch of unstable bouncing.
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 09-18-2015, 11:10 PM   #14
Rob43
Rob43's Avatar
This has everything to do with the quality of the dampers being used.
Rob43
Old 09-19-2015, 03:50 AM   #15
Alex323Ci
because coil-overs don't have "springs"
Old 09-22-2015, 09:41 AM   #16
CrowsFeast
My Ride: 330CI ZHP
Rob43
Seconded because of how important this is. PLEASE do your research and properly pair your springs and dampers. This will make or break a suspension setup.
Old 09-22-2015, 12:14 PM   #17
Redline
Redline's Avatar
My Ride: ///M3 Vert
Bilstein HD/Eibach pro kit springs. Eibach sway bars. You'll out handle any m3 on sub $2k coilovers and still ride like stock in terms of comfort. Coil overs suck on a daily.
k.
///M
coilovers, lowering springs
