Old 09-05-2015, 03:09 PM   #1
robboj
My Ride: 2000 323i
Help: E46 cylinder misfires
I have a 2000 323i that has been rough idling and has is much slower than usual. Service engine light is on, got back codes P0303 and P0302. Switched ignition coils between cylinders 1 and 2 to make sure it wasn't a coil. Code still read cylinder misfires in 2 and 3. Changed all spark plugs. Seems to run a little bit better, but SEL is still on and it's still idling around 900 RPM and generally just slower. Any other ideas of what it could be? I've heard intake boots are a common problem? About to go check that as well. Any help is greatly appreciated!!!
robboj is offline   Reply With Quote
Old 09-05-2015, 04:16 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Read my comments in this thread - http://forum.e46fanatics.com/showthread.php?p=16727145
cylinder, misfire, p0302, p0303
